- Sep 5, 2016
My Specs:
i5 2500k @ 4.5Ghz + CoolerMaster Hyper 212 1st gen
ASUS P8Z77-V BIOS v1908
Crucial Ballistix Sport DDR3 1600
Sapphire NITRO R9 Fury
ASUS Xonar DGX Sound Card
EVGA SuperNOVA 750 G2
Crucual MX100 250GB SSD (OS)
2x 1TB WD Blue 7200RPM HDD no RAID
DVD-RW Optical Drive
Windows 10 Pro Anniversary Update
HAF 922 Case 1x 200mm Front Intake, 1x 200mm side intake, 1x 200mm top exhaust, 1x 120mm rear exhaust.
MG248Q 1080p Freesync Display 144hz
Logitech G710+ KB
Logitech G502 Mouse
XBOX 360 Controller for Windows
This is what it looks like after 3 hours in Prime95 Blend. My Hyper 212 can keep it from going over 80C so far but I wish it would get cooler. My ambient temps is 80F (26.6C). What do you guys think, is it looking good? Should I start working on turning the vcore down .01 and testing? What other CPU cooler do you think I should start looking at? I was interested in the Cryorig H5/H7 or ID Cooling 240L. I'll need a better cooling solution for next build anyway.
I could also try to re-orient the top 200mm case fan as intake, I've heard that top exhaust sometimes messes with airflow of CPU fan.
Logitech G710+ KB
Logitech G502 Mouse
