MasterShakeJD
- Oct 11, 2012
I am using the stock hsf with the ASRock Z77 Pro3 board. The fan struggles to spin up after pressing the power button; it does like two intermittent quarter turns, then runs very fast before slowing down to a steady speed. The computer does seem ok though as I installed Windows alright.
However, when plugging the fan into a 3 pin header (instead of the CPU 4 pin header) the fan still acts the same way. I tried a stock intel fan from an old Core2Duo and it starts immediately when connected to either the 3 or 4 pin headers once the power is switched on.
After reasearching online I thought the first stock hsf was bad so I returned the processor. However, the new one acts the same way. Any ideas? Did I get two bad fans? I'd like to just use the stock one instead of buying another one but am not sure this is normal behavior.
Oh, I know the old Core2Duo fan could be used instead but I need that for another system.
