I wouldn't think there is much of a difference. Outside of benchmarks, I don't see much of a difference between stock and over clocks. 800mhz 6-6-6, 900mhz 7-7-7, 1000mhz 8-7-8, 1066 9-9-9, 1T 2T, it pretty much all feels the same..
That is because it more or less is. Raised timings take away from speeds.
this is a bit old and could use some updating.
Ram speed vs Ram timings
back in the day people thought i was crazy for sticking with DDR2-800@cas4 vs going higher. since there was no benefit of doing so in my eyes, i stuck with the DDR2-800. As DDR2-1066@cas5 was costing more then the ram i bought, even when it was the best out there. its cause and effect, to go higher speeds we need higher latencies. in turn over all latency for data going back and forth is the same.
just noticed, i overlooked the edit that FCG did. he has the table up to DDR3-2000 speeds, will still give people a good idea of how much they over pay for high speed ram with loose timings vs slightly slower speed with tighter timings.
my personal experience, i sold my 2x2gig ripjaw kit i bought DDR3-1600
[email protected] and went to 2x4gig kit sammy DDR3-1600
[email protected]/1.5v. the 4gig kit i paid nearly double the price for it back when i got my i7 rig. i noticed the sammy ram after some rumblings about ddr3 30nm ic's from them. even at 1.5v at the same timings some people where able to get the ram at ddr3-2000 from what i recall. they may in fact have used 1.65v instead on their i's. needless to say i bought two kits when i found them cheaper at the local frys even with tax vs newegg.com. currently just using one sammy 2x4gig kit, for gaming in Tribes:ascend@1900x1200 fps is the same, load times is the same. with the advent of IMC's on the cpu and people now using SSD's. you will find it very hard(you probably wont notice any difference at all) to feel/see any difference in ram speed for gaming.
also take into account that in the case of intel. pcie lanes are on the cpu so sending any data stored in the ram, any latency is nill. this isnt the day of data request to the cpu then through the chipset then finally to the pcie buss. i cant seem to find it atm but i dont recall if 2nd gen+ i's have sata on the cpu as well. this is another thing that will lower latency when data has to go from hd to either ram or to gpu. today there are so many things that seem to get missed in the overall performance of a system. now if you choked your rig even with the tightest possible timings on DDR3-1333 then you would be effecting your performance, DDR3-1600 is wheres the balance lies, anything over that and your just wasting money.
