[RESOLVED]
Dear friends,
I followed Miahallen's suggestions as referred to in this thread:
http://www.overclockers.com/forums/showthread.php?t=630823&highlight=settings
I run the GA-P55-UD3R motherboard (F4 bios) with an i5, and this G.Skill ram:
http://www.newegg.ca/Product/Produc...193&cm_re=g.skill_1600-_-20-231-193-_-Product
I believe I am being limited by my ram, as I did not run into problems at the Bclock level at all up to 190 Mhz and on stability test. However, I have trouble getting to 162 Mhz using 9-9-9-24, vtt 1.35v, vcore 1.3v, vdimm 1.66v. At 160 Mhz I am fine, beyond that I get errors right on boot up. My temps seem alright in HWmonitor and Speedfan. I am sitting at around 57c per core under Prime95.
Do you guys have any suggestions? This cpu has to have more than 3.4Ghz in store for my new build, or at least I hope. Other information:
Earthwatts 650w
Megahalem Mega Shadow Deluxe push/pull 1200 rpm
I have run DIY watercooling on two setups in the past, but it's been a while since I have attempted an overclock. The bios is much more complex than what I am used to playing around with.
I am not very comfortable with surpassing vtt 1.35v as Miahallen suggests. Should I really push further? I want a 24/7 setup and can live with a few 100 mhz less if it means a more stable/reliable system down the road. I'm just disapointed most people seem to be in the 3.6-4.2Ghz range.
I am stuck at 21x160. Not my proudest moment in OC.
Edit: I am reading the first post I link for the third time and realize I could use a x8 ram multi. Would that result in any diminishing returns? Is it worth it to push to 4.0?
Thank you
Dear friends,
Earthwatts 650w
Thank you
