- Apr 16, 2011
- Missouri
Whats the problem here? Did the MB socket bend my cpu? Should I return it? I know nothing of 12th gen.
That was my question.Whats the problem here?
I've run a couple of 3x120mm AIOs and they all perform similarly on these chips............because it's not the AIOs.......it's the chips and how they freely they use voltage on default settings. A vast majority of boards cannot even run a simple AIDA stress test (CPU/FPU/Cache with AVX, not 512) without thermally throttling these Alder Lake chips. I can overclock the 12900K to 5.1(all core, not boost)/4.1 GHz with a 3x120mm AIO.... because I use less voltage there overclocked than the system does at stock. I can set 1.25V for those clocks where at stock, I've seen 1.4V on turbo.I tend to think all AIO are weak with high output CPU's though.
That is a problem with me
You're talking the mounting backplate, right? Standoffs are the brass things the motherboard sits on.I bought the 1700 standoffs before I bought the mobo.
