Hi!
Putting together a new system and noticed the cpu was very convex. So much that it didn't even make contact with the base plate of the HS (Mugen 4) on ~30% of the IHS.
I'll disassemble it and try to measure the profile of the IHS, but I never had such a convex cpu before.
Did some quick tests on stock and sure enough was hitting 85C on some cores after a minute or two with prime95.
There was also a +20C difference between the cores, sure some difference is to be expected but 20C seems excessive.
It was also running much hotter than 3930K I tested before it :|
What do you think? Should I return it or lap it?
