CircuitBreaker8
Disabled
- May 4, 2004
- Silver Spring, MD
Whats the difference? Im getting my Abit AI7 soon, and I heard its the best motherboard for the 865 chipset. But whats the differences between the 865 and the 875
CircuitBreaker8 said:and the 865 doesnt have this?
CircuitBreaker8, Well im gonna be running my memory in 1:1. I read a review about the AI7 having a street racer mode, i never fully understood what that was. Is it basicly GAT?
SPQQKY said:I don't see anywhere in that article where the 865 does better than the 875.....
batboy said:The performance difference between the i865 and i875 is small. Not enough to worry about. The AI7 is a good mobo. The nice thing about the AI7 is the higher vdimm options, so you can run higher DDR speeds and tighter RAM timings. Don't get your hopes up about overclocking that 2.6C much higher than it already has been done. At 3.4 gig, that's already much better than average for that CPU. My guess is that it's already pretty much maxed out.
The 875 is the clear performance king here but the edge it has over the 865 is only 1-4 %, which is not very great.
Before running the tests we anticipated only a small performance improvement due to the dual channel configuration. However, the results showed that there was a major performance gain with this setup. The 875 showed a 5% and 8% improvement in 3DMark2001 SE and Quake III Arena respectively over itself when running in the single channel configuration. The improvement in CCW though was not very much, possibly because it is very tough to improve such high scores. The benefit of dual architecture is clearly visible by the SiSoft Sandra memory bandwidth test, which shows 60 % more memory bandwidth with the dual channel than with single channel. 865 also showed improvements in performance with the dual channel, though the difference is lower than of 875. Compared to 850, both boards won hands down. The 875 gave nearly 10-12 % improvement in graphics while the 865 was 7-8% higher. Again we didn’t see much of a difference in the CCW benchmark.
