- Oct 25, 2012
Long overdue to upgrade.
Yes I will overclock.
Reusing a few previous parts from my current machine:
Case: Cooler Master Cosmos II
PSU: Corsair AX1200. Still kicking and still a crapload of power.
GPU: R9 295X2 (won't work in my current mobo due to NF200 chip fail, literally brand new in box waiting for a new machine)
I don't need any peripherals, OS, or storage. Basically I only need: Mobo, RAM and CPU, and possibly a CPU cooler as I believe Hyper 212 EVOs aren't enough for the new-hot running i7 4790k, especially if one wants to overclock? Saving up $700-$800 for these 3 parts, hope to have enough by mid august. Of course, less is better but I am not skimping on quality, as I want the most expandability as possible.
I want to go all out, Dominator Platinums, best mobo I can find... just like I did my current machine. I do screw around with virtual machines quite a lot, and I do run multiple games at once, so I want 16GB of RAM.
http://www.amazon.com/Corsair-Domin...23&sr=8-1&keywords=Corsair+Dominator+Platinum
I really thought the best RAM around (or is there better RAM?) would be more expensive than that. Leaves ~$560 for the 2-3 other components. Is 2400mhz actually neccesary now? I have conflicting information regarding this, the old rule used to be 1600mhz was enough and any higher got you incremental (1-2%) performance increases.
No Asrock.
No AMD mobos.
Can you help me? I mostly need help finding a mobo, as the current high end ROG ASUS selection isn't up to par, with the Formula VII having an ugly shroud and the Maximus VI Extreme not supporting the newest processors.
No Asrock.
No AMD mobos.
