- Jan 23, 2013
- Oklahoma, US
So, I had some watercooling issues a month or so back - Long story short, realized I had a slow leak in my CPU block that, while the computer was running, must have been evaporating off almost instantly so I never noticed it, except that my water levels kept lowering slowly over the course of several months. Shut the computer down for once a few months ago, wouldn't boot back up correctly.
Pulled the water cooling out finally, and saved up to get some more fans and a Prolimatech Megahelms air cooler - Decided I don't know what I'm doing when it comes to water, and to go back to what I can handle. Slapped 2 Noiseblocker 400-1500 RPM fans on the cooler in pull/pull... The way the fans are made, I wanted to put them in push/pull, but the fan mounts for the cooler press against the blades of the fan in push mode, so had to mount them pull/pull instead. Running 3 of the same fans in the top, one at the exhaust, and another 3 in the front of the case. The tops are pulling, the three in the front is pushing - It all seems to work pretty well, keeps my FX down at a good 50C under load, which I don't consider to be too bad. IT's not overclocked, yet.
Now, the musings part.. Been thinking about upgrading to one of the Visheras, the 9590.. EVerything I can find though seems to reconmend watercooling with it, so if I went that route I'd probably get an AiO so I don't screw it up like I did last time.
Only reason I'd consider upgrading, is Fallout 4's recommended processor AMD-wise is a 9590. Hm.
Alternatively, I could keep the 8350, slap one of the better AiO's on it and overclock it up to 4.7.. Or even 5.0 (IIRC, 5.0's been a relatively easy, stable OC to hit on the 8350 under water) and get, basically, the same thing.
Thoughts?
Thoughts?
