- Apr 28, 2001
To measure your CPU temp idle, do you just leave the pc with nothing happening for 2 hours and then check the temp.
To measure your CPU temp full load, do you just leave the quake 3 demo for 2 hours and then check the temp.
Is the above correct.
PS- what is better thermal tape or grease
