- Jun 10, 2003
- Eldersburg (Sykesville,) Maryland
Title says it all. Since I built my PC I've been using the onboard AC 97 audio on my IC7. Luckily, I haven't had a lot of the same issues that other people have with their onboard audio with this board- no hissing or crackling. However, when playing music the sound is pretty muffled sounding, and surround sound doesn't work all that great. Most of the time it doesn't sound like individual sounds are being sent to seperate speakers, it just sounds kind of smooshed together (the settings are definitley set right too, so its not that.) Preferably I'd just like to up the volume of my rears a bit more as they get pretty drowned out, but it doesn't seem like I have that option. Every once in a while, my sound just cuts out until I reboot as well.
My speakers are pretty nice, Logitech Z-5300's.
So, I"m looking at what PCI card to get so I can say goodbye to my onboard. I've narrowed it down to three, going from cheap to fairly expensive.
http://www.newegg.com/app/ViewProductDesc.asp?description=29-120-103&depa=0 Chaintech AV-710, $24
http://www.newegg.com/app/ViewProductDesc.asp?description=29-121-116&depa=0 M-Audio Revolution 5.1, $65
http://www.newegg.com/app/ViewProductDesc.asp?description=29-102-162&depa=0 Audigy 2 ZS, $85.99
-Another possiblity would be someting made by Turtle Beach, but I haven't the slightest idea of what would be a good card from them. I had one of their cards 5 years ago and it was pretty good...had some weird compliancy issues now and again though.
I've been reading this section of the boards a bit, and whenever gaming is an issue the overwhelming response seems to be "go creative!" Two things about creative cards for me though- one, the expense (although honestly, would I notice a difference in sound between an audigy 2 and an audigy 2 ZS? The regular 2 is cheaper) Two, every time I install a creative product, it is a titanic battle to make the drivers install correctly so the product works at all!
The big thing going against the non-creative cards seems to be cpu utilization and framerate loss. My question is, what sort of difference would I see in fps loss/cpu utilization between onboard sound which already uses my cpu, and the chaintech or m-audio card? Similar performance, worse performance, or a little improvement even?
Thanks.
Thanks.
