- Dec 5, 2004
- Milwaukee, WI
O.K. guys, here's whats up:
I've had a golden 955XE chip that was just insane, but voltage NEVER, went over 1.55v (ran at 1.5125v stable daily)
But about a month ago it had begun to lag and chop in windows, which I thought was a HDD problem, but it persisted even after 3 reformats and even reformatting with the drives taken out of RAID - then later on it began to actually hard lock in windows (with no BSOD), and then a week after that started, it refused to boot into windows period
I attributed it to my PSU, so I tried a friends and it atleast booted into windows a few more times, but then again refused to load windows again... ordered a Zippy 700w PSU, still no windows boot
since then, I have gone through the following to try and troubleshoot everything:
-Asus P5WD2-Premium 955X w/ 0606 or 0704 BIOS
-Intel D975XBX 975X w/ most recent BIOS
-2x Hitachi T7K250 250gb SATA II (currently out for RMA as another attempt to try and make stuff work)
-Maxtor MaxLineIII 300gb SATA II
-Sapphire x1900XTX
-Sapphire x1900XT
-PCP&C 510ASL 510w
-OCZ Powerstream 520w
-Zippy PSL-6701P-SATA 700w
-3 Windows XP Pro install disks (all with SP2, dont have anything else)
-Windows XP Home install disk
-15-20 SATA/SATA II HDD cables
-4 IDE cables
trying everything above, switching everything out, trying it out of case and in case, etc., etc. - still nothing has made it work again
the 955XE will do anything you want it to in the BIOS, it will POST fine, and even pass a full 6 hours of memtest with ZERO errors, and it boots with a knoppix linux CD without any problems either
it will format a HDD for windows with both FAT & NTFS, will copy all setup files, but when when it reboots, it will lock up and/or restart when the GUI install begins (where you can use the mouse, enter your name and CD key, etc.), or if I install a HDD with windows already installed on it, it will get to the boot screen, load 2 or 3 bars, and then lock up and/or restart and repeat the attempted boot cycle
I've played with every voltage setting, tried all kinds of timings and who knows what else, re-flashed the BIOS atleast 20 times on the P5WD2-P and ordered the new D975XBX because I thought the SATA controller on the P5WD2 was toasted
I've played with the Hitachi drives in Hitachi Feature Tool, setting them to every which way, both SATA 150 and SATA 300, same stuff happens - have tried both the ICH7R SATA ports & the Silicon Image SATA ports
There is no way this chip could, or even should be dead if it does everything that I've listed above, but JUST NOT BOOT INTO WINDOWS :stick:
I am calling ALL people of expertise from every corner of the world to try and help me figure this out - I've stumped myself to the point of ripping my hair out, boggled atleast 5 of my friends, including mikeguava and Reinvent3d about this problem
so far the only somewhat feasable suggestion as to why this problem has occured is the fact that my 955XE may have a junked L2 cache (suggested by mikeguava), but he has NEVER, EVER seen that happen on an intel, or the way that I've explained it to him - the only time he's ever experienced that is with a coldbugged AMD CPU that would lock up in 3Dmark in the same spot every time
no peice of hardware in my computer has been tampered with, mishandled, or damaged in any shape, way, or form, that I know of, and all of it was in tip-top shape and 100% working order just a few weeks ago, but now I'm SOL and currently on a customer's machine while I wait for the last few parts for it to arrive
I also have a Celeron D chip coming on monday to try and troubleshoot things further, but I don't have any IDE drives that I can test stuff with (I have one with no windows install that I have EVERYTHING backed up on, and refuse to risk it with anything), and don't have an extra set of DDR2 available either, but with it passing 6 hours of memtest with the 955XE, it should be perfectly fine as far as I'm concerned
Please, I am open to suggestions from ANYONE at this point, even if its a half-assed poke at trying to solve my problem, I will do ANYTHING in my powers to make my rig work again
Please post here with any questions, comments, or suggestions, or feel free to contact me via email: [email protected], or on AIM: Sneakyl3astard to ask more questions or just have a 1 on 1 troubleshooting chat to see if we can sort anything out
Thanks in advance for any assistance that you may provide
-Justin Rubner
-Sapphire x1900XTX
-Sapphire x1900XT
-PCP&C 510ASL 510w
-4 IDE cables
-Justin Rubner
