- Nov 21, 2018
So i picked one up thought i'll give it a try with the new loop.
Now im to lazy to move my pc so i just put a tiny little dab of NT-H1 at the very top edge of the ihs. Not really anything. just a little light smear at the edge to keep the pad on the ihs why i mount my block.
Just played some wow 4.35ghz 1.35v typical oc for the higher binned 3900x's and depending on what program because they all are close at times then way off. Ryzen Master 59c after 2 hours of wow. So not to bad. Also pretty happy with all the new Corsair hydro x stuff. the Corsair commander for some reason wont push the d5 to 100%. i only keep it around 50 but for the first few hours i keep it at 100 to push air out so i plugged it into my mobo and just using that. probably doing something wrong with the corsair commander so ill get that sorted out another time.
But those pads work pretty good. May not be the best but if you been thinking about one give it a shot.
