- Nov 12, 2002
- Rootstown, OH
I'm looking to get into a serious overkill RAID0 storage setup for a very specific purpose. The only point is PCMark05, it won't be used for anything else. It's probably stupid, there are cheaper ways to get really fast storage, and it might be a bad idea... But I wanted to start a thread on it to get any useful input you guys might have on how to do what I'm doing the right way. I'm targeting 1st place in the world in PCMark05 on 8x CPU cores, then also other core configurations. I have a few questions.
The model RAID controller I'm getting is the Areca 1882IX. It comes in various flavors, but the one I'm getting is upgradeable to 4GB onboard cache - that is key to the performance I need on the HDD general usage and HDD virus scan PCM05 subtests. Other than that, the only variable is the number of internal/external connectors. This will be in an open air benching rig, so internal or external makes no usability difference.
First question, the upgradeable 4GB onboard cache. Per specs, it takes "One 240-pin DIMM socket for DDR3-1333 ECC single rank registered SDRAM module using x8 or x16 chip organization, upgrade from 1GB (default) to 4GB (ARC-1882ix-12/16/24)". I'm not sure what it mean by x8 or x16 chip organization. Looking on Newegg, I don't see any ECC DDR3-1333 that appears to have only 8 or 16 chips on the DIMM - am I being an idiot, and what sort of ram should I be getting to put this thing at 4GB? It is essential for my needs that I upgrade it to 4GB from the default 1GB.
Second question, these are the configurations I am considering purchasing. Only tangible difference is the number of internal SAS connections. Is there any functional/technical difference between the external or internal connections I may not be aware of? Drives will be sitting loose on my workbench, no enclosure or anything. I'm starting off with only 3 SSDs, but may move to 6 or more in the future if performance scales:
3 internal, 1 external: http://www.newegg.com/Product/Product.aspx?Item=N82E16816151112
4 internal, 1 external: http://www.newegg.com/Product/Product.aspx?Item=N82E16816151109
6 internal, 1 external: http://www.newegg.com/Product/Product.aspx?Item=N82E16816151114
Third question, which cables should I be getting to connect the SAS ports to the SATA SSDs? I'm targeting one drive per 6GB/s port, as I expect that would be optimal? However more drives may be added as necessary if more are needed, in which case I want to be able to expand the RAID0 array to 6 drives or more - ideally with as many as possible on their own ports. Will it affect performance doubling up drives per port? These are the cables I was considering getting, however they are expensive as crap. I need SFF-8087 for internal connections, and sff-8088 for external connections: http://www.newegg.com/Product/Product.aspx?Item=N82E16812200884
Are there less expensive cable options I am not finding?
FYI, I'm starting with 3 vertex 3 maxiops. Initial outlay of cash will be something to the tune of $1500-2000 for the storage.
