- Sep 30, 2020
Hi everyone,
CPU: AMD Ryzen 9 5950X
MOBO: ASUS ROG Crosshair VIII Dark Hero
I'm trying to figure out a way to install four M.2 NVMe modules on my new ASUS Dark Hero motherboard, which has only two M.2 slots.
The ASUS HYPER M.2 X16 GEN 4 CARD seems like great solution to add four extra modules, however, the only way for four modules to work on this card, is to use the first PCIe slot. I never heard about this, but this seems related to Bifurcation and being able to run two or four modules, depending on which slot I'd use. Slot two only allows me to use 2 modules.
So basically, if I want to continue with this GEN 4 card, I have to install my future RTX 3080 card in the second PCIe slot. Which, according to the manual (click here) on page 1-8, should be x16 as well? Or do those dashes mean that it's not x16?
I was hoping if anyone could tell me if I'd lose any GPU performance from using the second slot.
Thank you!
Thank you!
