hi i have 2 socket 478 cpu's, 3 actually but one is just a slower Willamette(1.5Ghz)
the mobile P4 shows up as a northwood in cpuz and is a 2Ghz cpu but will only run at 1.2Ghz due to speedstep(is their any way to disable speedstep on the cpu to have it run at full speed)
http://processorfinder.intel.com/details.aspx?sSpec=SL6FK
i also have a 1.8Ghz Willamette
http://processorfinder.intel.com/details.aspx?sSpec=SL5UK
the motherboard i have has ddr226 ram and is a oem motherboard, disabling me from changing chipset and cpu settings
my question is witch cpu should i use since i know that the Willamette cpu's have been beaten by P3's
i also have a P3 667mhz with pc133 ram if that would be any better
i plan to use the computer mainllyfor a weather station logger and file server but also plan to do some small gaming on it if it has the power(it will have a geforce fx5950ultra) it will also probbly run as a web server.
