yea, i was looking at getting the GB gaming 5 or the MSI gaming board. They all have killer nics, the same onboard audio ic. the Asrock has more phases then the GB but less then the MSI. To me for the price its the best bang for the buck. though i will admit without knowing the current rating on the msi chokes i dunno if the higher phases is the same as the asrock board or better. same thing goes for the gb gaming 5 board, is it 20amp,38amp or 60amp chokes.The same in Poland. Pentiums are still not listed or all are waiting for delivery. Premieres are in the same time in US and PL ... we have simply delays because of 2-3 distributors and stores on the way.
I see you have decided on ASRock Z97M OCF. I think it's probably the best board for this price ... still thinking if I should get one or not.
yea thats what i keep reading, i havent bought a oc'ing board since my gene in sig. last time i used a asrock board was for my little round up of LGA1156 boards many moons ago. had some nice ocing features back then, just was lacking a bit in the power section for the cpu.the asrock oc formula boards are awesome
That is the world of advertising leave out the important speciation's.yea, i was looking at getting the GB gaming 5 or the MSI gaming board. They all have killer nics, the same onboard audio ic. the Asrock has more phases then the GB but less then the MSI. To me for the price its the best bang for the buck. though i will admit without knowing the current rating on the msi chokes i dunno if the higher phases is the same as the asrock board or better. same thing goes for the gb gaming 5 board, is it 20amp,38amp or 60amp chokes.
i forget what i was reading that talked about switching frequency, in relation to interference or distortion. it had something to do with how the peaks in the frequency could/did creep into the lower range causing issues. when the frequency was pushed higher that the creep into the lower range moved up. that the range actually being used was free of these "issues" leading to a cleaner signal which allowed for "improvements". these improvements could be things like how clean the voltage output was on a switching power supply or less of a drop in voltage under load to even being a cooler running power supply under load. those were a few things covered in the article or forum post, its been a long time since i was reading about power supplies. not PC based supplies but one for home audio amps when i was getting into that DIY area.Somehow optimal frequency for most chips was 350kHz and some are working better at 400+. Memory vrm frequency in OC mode is 600 or 700 kHz as I remember. That's actually helping in max clocks.
yea im sure the presets will help out people with little to no experience with ocing. i may be a bit behind in the ocing game but nothing i can figure out in short order. half the fun is in the tweaking!The nickshi memory presets are amazing on my Asrock Z77 OC formula.
And most of his OC presets will get you in the ball park when your first working a chip if you want to use those.
But the mem presets got all my subtimings right on a few kits of dif mem and with fairly tight subtimings too. All i had to change was Mem Voltage and tighten the primarys a little bit and everything worked .. on like 5 dif DDr3 Kits too.
Nothing but issues on my other Z77 Board with Mem Timings (secondary/tertiary )
Is it the board or Hasswell VR that you are controlling the VR frequency?Somehow optimal frequency for most chips was 350kHz and some are working better at 400+. Memory vrm frequency in OC mode is 600 or 700 kHz as I remember. That's actually helping in max clocks.
