Conclusion
So, what’s the bottom line? Intel is pushing the envelope once again with a factory-overclocked Xeon processor doing double-duty as a high-end desktop masterpiece. We're getting the sense, though, that the revered Core architecture can't be pushed much further. Everything works well enough this time around, at least. And if Intel hadn't chickened out and put thermal paste between its die and heat spreader, there might have been a happier ending for everyone involved in this story.
As it stands, even a custom water-cooling loop has to throw in the towel at 250W, long before most motherboard voltage converters hit their limits. Under normal operating conditions, the CPU, and not the motherboard, always throttles first.
Nevertheless, motherboard manufacturers aren’t blameless when it comes to the issues we encountered at launch and continue battling today. Using more thermodynamic expertise and less flashy plastic pieces would have paved the way for brawnier motherboards at the same price points. This would have ended the speculation before it even started. Anything designed to be just good enough always leaves you with a bad aftertaste, particularly since you never know when you might need a little extra headroom.
