- Dec 14, 2010
So, I decided to do a test for how much my Z97 would improve on an X58 system for gaming in Battlefield 4 a while back. The results were... surprising to say the least.
I started with the i5 4690K at stock and compared it to an Xeon L5630 overclocked to 3.6GHz. The L5630 won pretty easily. Then overclocked the i5 4690K to 4.2GHz thinking that would beat the L5630, but nope, the 4690K still loses.
Then I thought, okay, maybe the L5630 is winning just because of having more threads (8 versus the 4 of the 4690K). So I swapped out the Xeon L5630 for a Xeon E5506 (overclocked to 3.45GHz) (4 cores/4 threads), but the E5506 still managed to outperform the 4690K even when said 4690K was running 750MHz faster. Although, the FPS scores did drop when going from a 4C/8T processor to a 4C/4T processor on the same platform.
These benchmarks were run multiple times on both systems for the sake of consistency just in case one run was unusually better or unusually worse than the rest.
This honestly doesn't make much sense to me, with the Z97+4690K platform being much newer, having faster SATA transfer rates, faster memory, and higher IPC on the CPU it probably should have been performing better in my mind than a platform from 8-9 years ago with the same GPU.
Wasn't sure whether to put this in the GPU's forum or the Games forum, hopefully I put this in the right one.
CPU: Intel Core i5 4690K @ stock
Motherboard: ASRock Z97 Extreme6
Memory: 2x8GB G.Skill RipjawsX F3-1866C9D-16GXM (9-10-9-28 1T)
GPU: Evga GTX 780 FTW
SSD: Samsung 850 Evo 500GB
HDD: WD Black 1TB
PSU: Corsair RM650i
CPU cooler: Corsair H100i
Min: 91 Max: 169 Average: 124.33
CPU: Intel Core i5 4690K @ 4.2GHz
HDD: WD Black 1TB
PSU: Corsair RM650i
Min: 106.44 Max: 175.67 Average: 139.56
CPU: Intel Xeon L5630 @ 3.6GHz
Motherboard: Asus Rampage III Formula
Memory: 2x8GB G.Skill Ripjaws F3-12800CL8T-6GBRM (8-8-8-24 1T)
SSD: Samsung 840 Evo 120GB
HDD: WD Black 500GB
PSU: Corsair TX750
CPU cooler: Cooler Master Nepton 280L
Min: 126 Max: 186 Average: 150.928
CPU: Intel Xeon E5506 @ 3.45GHz
HDD: WD Black 500GB
PSU: Corsair TX750
Min: 108 Max: 182 Average: 138.156
HDD: WD Black 1TB
PSU: Corsair RM650i
HDD: WD Black 1TB
PSU: Corsair RM650i
HDD: WD Black 500GB
PSU: Corsair TX750
HDD: WD Black 500GB
PSU: Corsair TX750
