Finally looking at upgrading my 2600k system i built about 8 years ago. I'm also using an i7 920 system next to it.
Need some advice on what route i should go...
A) I can pick up tomorrow a MSI Trident X Gaming Desktop at 20% off for $1850 + tax https://www.bhphotovideo.com/c/product/1455691-REG/msi_trident_x_9se_003us_i7_9700k.html
it has
3.6 GHz Intel Core i7-9700K Eight-Core
16GB DDR4 | 256GB NVMe SSD + 2TB HDD
NVIDIA GeForce RTX 2080 (8GB GDDR6)
USB Type-A & Type-C | HDMI | DisplayPort
Wi-Fi 5 (802.11ac) | Gigabit Ethernet
MSI Mystic Light RGB LED Lighting
Windows 10 Home (64-Bit)
The board is a $150 MSI z370i gaming carbon AC and video card is $700 MSI rtx 2080 ventus
Videos posted about the review of this system are good and tested running 4.6 on all cores, not bad for just air cooled.
The negatives would be the cpu probably won't reach its turbo'd potential of even 4.9 under air and such non flow, small case. Also the ram i read is terrible... 2600 on green board no shielding at all. HD is 5400 rpm. I can easily swap those out though
B) I can just pick up a 8700k $10 cheaper than the ryzen 2700x
Get a better motherboard z390 series...either the gigabyte aorus pro wifi or MSI MPG Z390 Gaming Edge AC Motherboard. Open to other board suggestions but both these had good reviews and in stock ready to pick up immediately. I threw the msi in because i've had extremely good success with them. Both my 8 and 10 year old current systems run msi board and i have 2 msi gaming laptops dating back 4 years...no issues with all.
I can get 16gb of high quality 3600 ram like gskill tridentz or corsair rgb pro
Pick up a corsair h150i cooler and a additional corsair 3 fan kit to run push pull
Use the stuff i already have, which is a thermaltake P5 case new in box. Move over my Antec 1000w PS i put in my 2600k system 8 years ago and was $280. Also move over my evga 980ti video card and 2 500gb samsung evo 360 ssd's
So my total cost with this is about $1000 Essentially the difference not having the new video 2080 card. But I would have better ram, board and room to overclock beyond 4.6 that i would get with the trident X, albeit less cores.
C) Just wait it out for ryzen 3k and either go for that or a 9900k. I would go open loop cooling in a thermaltake 900 and system would probably cost me $2500
Open to suggestions/hardware changes, thx
it has
