- Jan 14, 2011
xbmc with an htpc is awesome
we just canceled our dish and are using sickbeard tpb version / netflix so we dont have to use a usenet account, you dont get the awesome download speeds but in general i have tv shows within an hour of them showing on tv still with most of the shows being set to HD.
although i have sickbeard and couch potato running on my main server and just stream everything over gigabig i was using wireless G for a long time till my HD movies started to peak 10gb or so then they started buffering alot, and i have had the worst luck ever with wireless N, i have 3 wireless routers and several wireless N adapters none of them i have ever got to work right, like less than an mb/s not right. i havent tried AC but it seems feasible il have to look into that
i do need summore storage only a 2tb raid5 but with a server doing all the heavy loading / transcoding / downloading you can get away with a very light machine running the media center / xbmc.
only thing i didnt like about plex was when some one told me to check out the folder in appdata, i about crapped a brick apparently no one ever thought those guys what sql was lol the database was made of hundreds of thousands of folders 80% of them empty.
both of my htpc's are older low power c2d's but ive heard of people having luck with the newer atoms / APU all in one boards, even raspberry pi's.
i need to look into prime video, netflix is already starting to throttle my connection
