- Mar 10, 2004
- Texas
- Thread Starter
- #101
edwardaune, no problem dude. I had to learn by trial and error...never ever again will I buy a jet black truck.
thats funny
3) wetsand the case, clearcoat it, wetsand the clearcoat, paint the mural, wetsand, then a final clearcoat over everything, wetsand it all and buff.
ok threadjacker , why would you want to put a clearcoat down before you paint the mural, to add depth maybe?
and just to clarify diggrr, prettyt much up to this point Ive only been putting on one coat fo clear, but a thick coat. Are you saying that I should put on a few coats? And if so, do I need to be sanding in between those quotes. Thank you oh great on for your abundance of paint knowledge, are you glad you replied to this thread
