- Aug 17, 2002
Hmmm, seems like the best forum to put this in....
A couple of questions..
I'm thinking of buying an Ipod, and I've heard that they can be updated to support other music formats. As I want to transfer all my CDs to WMP and onto the ipod, they'll all be WMAs not MP3s, and it'll take ages to find some way of turning them into MP3s, so is there either
A) a WMA patch for the Ipod or
B) an very simple easy way to mass-make songs MP3 format?
Also, how do i make playlists on the PC to transfer to the Ipod? Does it just use WMP's usual playlist function?
And finally, i've heard that the Ipods are very buggy, and have problems like backlit screens not turning off, battery indicators not working, and the unit crashing occasionally, but some are fixed by firmware. Does anyone know:
A)What are all the affected problems
B)which have been fixed
C)when the others will be fixed by (approx) by firmware
Or is it worth waiting for, say half a year and getting one then when the problems have been ironed out?
Thanks
(BTW: in case you're interested, here's the apple post i made with this in. No replies as going to press :/
Thanks
