I havent run 3dmark test in years mainly because i always thought it was trivial and pointless and never showed real world gaming. I just bought a 4890OC on newegg and it had a copy of 3dmark vantage pro. Decited to run the test a couple times before i swapped my 4890 in.
I got 8173. It is really hard to tell whats normal or not on the ORB because some 4850's are getting 12k and others are getting 7k, so i cant tell what is crossfired and what isnt. From what i can tell tho it seems for a single 4850 i am Number 3 with an E8400 i think at least. Could someone confirm this ? The last results on the orb where someone said "crossfire" was a score of 9k, then the scores go from 8400 to 8200 then to mine. It also seems i dominate on the CPU results obviously im overclocked pretty high, but my GPU score is lower then there's even for such a high overclock.
Altho when i come accross quad's there scores are much higher, so i guess vantage must use 4 core then, because there is no way in real world gaming on current games a Q6600 at 3.4ghz would out perform my E8400. Thats why why i dont like 3dmark it doesnt show real world value's, i get 20% more fps in the games then these people with Quad's even some I7's at 3.5ghz but there score's are only higher because the cpu's tests are double mine hence 2 more core's
http://service.futuremark.com/compare?3dmv=1143982
My specs i used on the run were
E8400 @ 4.4ghz
G.skill DDR2-800 @ 978mhz
4850 @ 740/1150
E8400 @ 4.4ghz
4850 @ 740/1150
