- Jan 18, 2009
- Clearwater FL
I'd never snip anything off a psu myself personally.
Thanks for the heads up. I checked and fortunately the G-550 by Seasonic does have 6 connectors. The external drives are/will be all bus powered.Count connectors too. You list 4 SATA internal devices. (I'm assuming the external SATA devices have their own power supplies.) Do the smaller PSUs have this many SATA power connectors? Adding splitters is not a big deal but could easily make a smaller PSU as expensive as a bigger one.
Wait, did you post the wrong link? That's a 500W, not 750W.
Well, technically a 750W would allow the future possibility of SLI, which I might go for at some point. However, I could always sell the 550 and buy a new on if needed.
I think I peak a bit over 425w AT THE WALL which is around 375w actual use (platinum efficiency) .I run a 4930K @ 4.2Ghz ~1.2v and a GTX 780 Lightning with a 560W PSU and the fan barely spins up on it.
frig my bad.Not enough posts for classified access bud.
Just to out this out there...
The difference in price of the 500w model and 750w model is $40. $50 for the 500 and $90 for 750w or 80% more than the 500w.
I wouldn't run a psu at 90% of it's label either... But it wouldn't do that on his system in the first place.
This is where we diverge...and here is my logic, rooted in facts.If you're not upgrading any time soon, and you're happy with stock t hings, than yeah a 500-600 is more than plenty.
Thank you everyone for your suggestions and opinions. As EarthDog and me seem to have a somewhat similar setup, I think I trust his judgement in the matter and I'm positive that 550W would be more than enough. However, yesterday I stumbled upon Seasonic's P-660 and after some thought have decided upon that one. It cost just a little bit more, so I thought what the heck. The reviews I read about it were so over-the-top fantastic, that I couldn't resist
Thanks again! PS. Even though this correction's two pages late... I'm not a 'he'
Hehe, yeah, I read that too. JG's conclusion comments were amusingOh, that's a seriously solid unit. JonnyGuru gave it a 9.6/10, only lost points on "value"!
Also, hullur!
Also, the online store that I found the P-660 on had a long text underneath, stating that they (the owners) rarely write anything about their products, but that this PSU is so fantastic that they had to give a heads up. "This isn't mere advertising any more, this is just the greatest PSU ever made, trust us on this and buy it!"
Here is the thing...it is really situation dependent and you estimates are overestimated. The TDP values of CPUs and GPUs are only hit when they are maxed out at 100% use with something like F@H, mining, or running stress tests. When gaming, even when overclocked, I barely hit the TDP of some cards. For example, my 780 Lightning. I was able to raise the voltage and clocks to 1320Mhz (from 11xx), and hit 108% power so 270W total overclocked. Remember that GPUs have power limits. CPUs are about the same. This OP said "slight" overclock on the CPU so I do not imagine it to use more than the TDP honestly...
Like I said, I run a 780 Lightning (same TDP as his 580), and a 4930K with a "slight" overclock (4.2Ghz), and I peak around 425W AT THE WALL. I have seen 475W (AT THE WALL) when overclocking the 4930K to 4.7Ghz and the Lightning to that 1320 MHz core. The fan on my Seasonic X560 will occasionally spin up (its temp controlled). I also ran a GTX 690 on it and it peaked around 500W (AT THE WALL). The 580, IIRC, does not have those power limits, but assuming he is not volt modding and such, I wouldn't be worried.
So I stand by the statement that a quality 550W PSU will handle any single GPU system, even overclocked... outside of an AMD Octco FX overclocked to the moon.
