Hey guys, new to the forums here and thought this would be a good place to get some help diagnosing my performance issues.
I've had an Asus GTX 670 DCII (Non TOP) for 2 months now ever since I upgraded all the major hardware in my rig. Here are my specs now:
CPU: I7 3770K Stock
GPU: As mentioned, stock clocks.
MOBO: Asus P8Z77 V-Pro
RAM: 16GB Corsair Vengeance 1666
OS: Win 7 64
Power: Corsair 850 TX
HD/SSD: WD Caviar Black 500 GB/Intel 520 180GB
Displays: 24" 1920 X 1080 as my main and 22" 1680 X 1050 as second in dual-display setup.
I'll cut straight to the point now. How is it possible that my Unigine Heaven Benchmark scores at max settings are 15-20% lower than -every single- other GTX 670 benchmark i've seen, the majority of those systems having weaker hardware than mine.
See here http://postimage.org/image/dxsscz8qx/
The average total score i've been seeing on the net is about 1150-1200. My friend has the exact same GPU as me, but a weaker I5 2500K. Our rigs are otherwise identical. His scores are higher. It gets better though. Before I built my new rig setup, I built my girlfriend's PC right before. It's essentially a clone of mine with the exceptions being that both her monitors in dual display are the same as my 24" main. She also runs an I7 2600K on a P8Z68 V-Pro, and an EVGA FTW 670. Essentially very similar rigs, YET her lowest FPS were twice as high as mine, and her highest FPS was 30 more than mine.
Her benchmark score was around 1100.
In addition to this, my gaming performance at full 1080 has been pathetic. Skyrim will dip below 30 FPS with 3 mudcrabs on the screen or if i'm INDOORS and there are fog effects. Crysis maintains at 30 FPS or lower with only the ingame settings maxed and no control panel tweaking. GUILD WARS 2 LAGS!? Metro 2033 had a blue hue invading the menu screen and in game, making it unplayable. When I tweaked the settings a little in the options, there were black and yellow artifacts trailing from all objects on screen. It was like an 8-bit game on LSD.
Do you think I can contact Asus customer support and have them replace my GPU?
CPU: I7 3770K Stock
OS: Win 7 64
