- Aug 25, 2011
- Denmark
My pc have been acting weird for the last couple of days. it had no warning shutdowns. no BSOD, no odd behavior pre shutdown or anything else. then i read a bit and started to see if i could find the source of the problem that made it shutdown. i started with clearing the Cmos so that everything would run at stock speed. that didn't help and i went on to check the ram. they weren't the problem. so that left out the psu, so i grabbed a multimeter and checked the voltages.
what is saw was the 12 volts read 12,25 volts. the 5 volt read 5,10 volts. is that okay? or could something else be the problem?
