The idea is that isopropyl will leave little/no residue. Finger oils or residue from other cleaners will have a lower w/mk than your average TIM and thereby reduce cooling potential. You ideally want nothing but the absolute best heat conductor between your IHS and heatsink. Well i guess ideally you want 0 micro-fizzures and no need for TIM at all, but you get the ideaI didn't quite catch where the idea that using isoprop leads to better temps came from. It just makes the cleaning easier imo, nonetheless you should always see that the surface is cleaned perfectly. And then it doesn't matter what you used.
Like 5 years ago I purchased this kit and it lasts me until today. I don't swap coolers every 3 month but once in a while I clean my rig or set up a friends rig. And a pack of coffee filters should end up with something like 100 pieces for like 50 cents or so.
I like having this stuff just laying around in case.
What paste? If its non-conductive (it probably is or you wojld have fried something) then you might be in the clear. You should still clean as best you can with a toothpick.... But maybe... If it aint broke dont fix it? If its a conductive/capacitive paste then I suggest you start counting the hours until failure and report back how long everything held togetherUhm... I sort did exactly that.
Okay heres the SitRep: Some of the Compound Squeezed out the right side of my Socket while I was lowering the Heatsink.... So I lifted the HeatSink and tried to wipe it off... however i couldn't reach because the Socket was in the way.... So... I... Lifted.... The.... CPU..................................................... The Paste ran down the socket and got over about three of those tiny Holes.... also the Very Edge of Underneath the CPU has got Paste on it, its touching pretty much the entire first Row of Pins on that side. I tried getting Rid of as much of it as I could with the Spirits but the **** just wont all come off.
[Deep Breaths].... So I said Screw It... I put the 212X Back on Shove the Board back into my Rig, Pressed the Power Button and Crossed my Fingers.... It didn't work ......
I opened the Side Panel and my R7 360's 6-Pin Lead wasn't Connected...... So I connected it.... and it Booted just fine..... well almost.
My Bios was not as I left it, but other than that. everything seems fine. My Temps are Down, the Rig is Finally Quiet (Still need to replace some Case Fans).
So... Exactly how badly did I **** up and how far into the future is this going to come back and Bite me in *** ?
I would probably leave well enough alone as long as everything is working right, but Ive been known to kick hardware that doesnt behave so you might not want to follow my example
If you really want to clean it out of the socket get a can of electrical contact cleaner. Take the mobo outside and spray the paste out of the socket. Let it dry and the reassemble it.
If it is what came with the heat sink, then very likely non-conductive.Its the Thermal Paste that came with the 212X... its got no details on the label and can't any info on it from CoolerMaster's Website.
- - - Updated - - -
Electrical Cleaner ?
Awesome, where can I get some ?
I know you are not in the U.S. so I do not know where you can source it, but there is a link below for what I am talking about.
https://www.amazon.com/gp/aw/d/B000...ct+cleaner&dpPl=1&dpID=411CvV4yAwL&ref=plSrch
