- Apr 30, 2003
- Chicago
Hey everyone,
I looked through about 30 pages of stuff on the web before posting...
I have (2) Comcast High Def DVR boxes at my house and I want to be able to expand the recording time of HD TV shows. The larger box has a 160GB capacity which equates to only 20 hours of programing.
Here are the 2 models I have:
Motorola DCT 3412I (The "12" at the end means 120 GB version)
Motorola DHC 3416 (The "16" means it is the 160 GB version)
Here are some problems I've read about which may or may not be true:
1. According to all the stuff I've gone through, it looks like on Motorola products, the USB and eSATA ports are disabled? ...So you can't use an external hard drive!
2. If you swap out the internal hard drive for a larger one, the firmware just reformats the Hard Drive to the same size as the old one and no extra room is able to be used. (Most Hard Drives don't work at all apparently?)
3. The eSATA port could possibly be used but you need to change the firmware to activate it and I don't know how to do that?
4. The firewire port can be used, but only to transmit to a PC for direct recording using video capture. (I don't care about recording stuff like that, I just want to expand the Hard Drive space on my Comcast DVR.)
5. Both Comcast and Motorola are no help at all if you call them or e-mail them.
6. There might be a way to use my computer, (which I have sitting right next to my Comcast box, and connected to my AV Receiver with a HDMI cord) to act as a DVR... That would be my last option because there would be complicated issues with anyone else in the house who wants to watch TV...(learning how to use the computer, how to use the software, how to switch over the AV receiver and inputs.)
Any ideas anyone?
Any ideas anyone?
