I have a i7 CPU and a Radeon HD 7950 GPU. I am currently water cooling the CPU only with a Alphacool NexXxoS UT60 Full Copper Triple 120mm Radiator. Also I am using a 6 fan push-pull setup. I want to add the GPU to the water cooling setup since I have found the waterblock to work with the 7950. Do you believe my current RAD with the push-pull setup is enough to keep the CPU and GPU cool? And if so what setup do you recommend? RAD-GPU-CPU or RAD-CPU-GPU or CPU-RAD-GPU?
Also I run my push-pull fans at top speed (noise is not an issue).
Thanks
Bocko
Thanks
Bocko
