markodude,
I assume that you went ahead and cut large holes through the top of your case, right? Otherwise, the only way air can move through your rad and fans is through those little tine holes that came with the case that shows up on your first round of pics. If that's the case, you'll be really hurting temp wise.
If you haven't cut the large holes yet, then don't bother. Just space up the rad and take off all of that duct tape.
