- Sep 8, 2002
- Connecticut
Hi everyone,
I am having some weird issues and hoping someone is able to help me understand what's going on.
I had this card running with the stock cooler and everything was fine, except for the heat. I was able to run Precision XOC and just enable KBoost and have my gpu clock running nicely around 1800 MHz, but between 75-80 degrees.
I received the hybrid cooler for Christmas and thought everything went smoothly. I booted up and speeds were running at the default clock (1569 core and 1376 mem) with the temps down in the 30's, woohoo!
I load up XOC and can't get much done because any sort of overclock now freezes the computer. When it comes to, everything is bogged down and Windows essentially becomes a slideshow. I restart, uninstall everything (even driver with DDU) and reinstall (same drivers and same XOC version). Try to overclock again after restarts, same result.
At this point, I switch to MSI AB. I increase core and memory clocks, hold my breath and hit apply. Success, computer is still alive! Head over to GPU-Z and notice discrepancies between the default tab and sensors tab (screenshots attached).
Now I understand these cards will reduce clocks when card is not at 100% load, but I am running 100% load and I cannot get the core clock to increase for the life of me. The other weird quirk I have is that whenever I try to just increase the Power Limit by just 1%, computer freezes up. I don't believe it's a heat issue as temps look better than before, but could it be the cooler's fault still? Also, I can't seem to mess with the voltage at all. Funny thing is, when I OC the memory, the voltage drops down. I think it was running at ~850mV stock.
Any help, advice or tips would be appreciated. Thanks!
