Newb to bonic. I followed the guide, and I'm running the optimized client. I had been running 2 clients for both cores, but I just checked and bonic says its only running one for SETI. It only lists one project. The second one isn't there anymore.. I'm confused...here is the log/messages.
Code:
9/4/2007 8:28:52 PM||Starting BOINC client version 5.10.13 for windows_intelx86
9/4/2007 8:28:52 PM||log flags: task, file_xfer, sched_ops
9/4/2007 8:28:52 PM||Libraries: libcurl/7.16.1 OpenSSL/0.9.8e zlib/1.2.3
9/4/2007 8:28:52 PM||Executing as a daemon
9/4/2007 8:28:52 PM||Data directory: C:\Program Files\BOINC
9/4/2007 8:28:52 PM||BOINC is running as a service and as a non-system user.
9/4/2007 8:28:52 PM||No application graphics will be available.
9/4/2007 8:28:52 PM|SETI@home|Found app_info.xml; using anonymous platform
9/4/2007 8:28:52 PM||Processor: 2 GenuineIntel Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz [x86 Family 6 Model 15 Stepping 2]
9/4/2007 8:28:52 PM||Processor features: fpu tsc pae nx sse sse2 mmx
9/4/2007 8:28:52 PM||Memory: 1022.41 MB physical, 2.40 GB virtual
9/4/2007 8:28:52 PM||Disk: 30.00 GB total, 3.56 GB free
9/4/2007 8:28:52 PM|SETI@home|URL: http://setiathome.berkeley.edu/; Computer ID: 3707023; location: (none); project prefs: default
9/4/2007 8:28:52 PM||No general preferences found - using BOINC defaults
9/4/2007 8:28:52 PM||Reading preferences override file
9/4/2007 8:28:52 PM||Preferences limit memory usage when active to 511.21MB
9/4/2007 8:28:52 PM||Preferences limit memory usage when idle to 920.17MB
9/4/2007 8:28:52 PM||Preferences limit disk usage to 1.86GB
9/4/2007 8:28:52 PM|SETI@home|[file_xfer] Started download of file 11mr07ab.10430.17250.6.5.175
9/4/2007 8:28:52 PM|SETI@home|[file_xfer] Started download of file 11mr07ae.25441.188260.3.5.176
9/4/2007 8:28:52 PM|SETI@home|Sending scheduler request: To report completed tasks
9/4/2007 8:28:52 PM|SETI@home|Reporting 2 tasks
9/4/2007 8:28:57 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 8:28:57 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 8:28:57 PM|SETI@home|Reason: requested by project
9/4/2007 8:29:15 PM|SETI@home|[file_xfer] Temporarily failed download of 11mr07ab.10430.17250.6.5.175: system connect
9/4/2007 8:29:15 PM|SETI@home|Backing off 30 min 24 sec on download of file 11mr07ab.10430.17250.6.5.175
9/4/2007 8:29:15 PM|SETI@home|[file_xfer] Temporarily failed download of 11mr07ae.25441.188260.3.5.176: system connect
9/4/2007 8:29:15 PM|SETI@home|Backing off 1 min 0 sec on download of file 11mr07ae.25441.188260.3.5.176
9/4/2007 8:30:15 PM|SETI@home|[file_xfer] Started download of file 11mr07ae.25441.188260.3.5.176
9/4/2007 8:30:37 PM||Project communication failed: attempting access to reference site
9/4/2007 8:30:37 PM|SETI@home|[file_xfer] Temporarily failed download of 11mr07ae.25441.188260.3.5.176: system connect
9/4/2007 8:30:37 PM|SETI@home|Backing off 1 min 0 sec on download of file 11mr07ae.25441.188260.3.5.176
9/4/2007 8:30:38 PM||Access to reference site succeeded - project servers may be temporarily down.
9/4/2007 8:31:37 PM|SETI@home|[file_xfer] Started download of file 11mr07ae.25441.188260.3.5.176
9/4/2007 8:32:31 PM|SETI@home|[file_xfer] Finished download of file 11mr07ae.25441.188260.3.5.176
9/4/2007 8:32:31 PM|SETI@home|[file_xfer] Throughput 7196 bytes/sec
9/4/2007 8:32:32 PM|SETI@home|Starting 11mr07ae.25441.188260.3.5.176_2
9/4/2007 8:32:32 PM|SETI@home|Starting task 11mr07ae.25441.188260.3.5.176_2 using setiathome_enhanced version 527
9/4/2007 8:59:40 PM|SETI@home|[file_xfer] Started download of file 11mr07ab.10430.17250.6.5.175
9/4/2007 8:59:44 PM|SETI@home|[file_xfer] Finished download of file 11mr07ab.10430.17250.6.5.175
9/4/2007 8:59:44 PM|SETI@home|[file_xfer] Throughput 94664 bytes/sec
9/4/2007 8:59:45 PM|SETI@home|Starting 11mr07ab.10430.17250.6.5.175_1
9/4/2007 8:59:45 PM|SETI@home|Starting task 11mr07ab.10430.17250.6.5.175_1 using setiathome_enhanced version 527
9/4/2007 10:49:15 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:49:15 PM|SETI@home|Requesting 1007 seconds of new work
9/4/2007 10:50:00 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:50:00 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:50:00 PM|SETI@home|Reason: requested by project
9/4/2007 10:50:00 PM|SETI@home|Deferring communication for 1 min 0 sec
9/4/2007 10:50:00 PM|SETI@home|Reason: no work from project
9/4/2007 10:51:00 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:51:00 PM|SETI@home|Requesting 3135 seconds of new work
9/4/2007 10:51:15 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:51:15 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:51:15 PM|SETI@home|Reason: requested by project
9/4/2007 10:51:17 PM|SETI@home|[file_xfer] Started download of file 12fe07ab.32098.307684.15.5.18
9/4/2007 10:51:22 PM|SETI@home|[file_xfer] Finished download of file 12fe07ab.32098.307684.15.5.18
9/4/2007 10:51:22 PM|SETI@home|[file_xfer] Throughput 112182 bytes/sec
9/4/2007 10:54:31 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:54:31 PM|SETI@home|Requesting 728 seconds of new work
9/4/2007 10:54:36 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:54:36 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:54:36 PM|SETI@home|Reason: requested by project
9/4/2007 10:54:36 PM|SETI@home|Deferring communication for 1 min 0 sec
9/4/2007 10:54:36 PM|SETI@home|Reason: no work from project
9/4/2007 10:55:36 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:55:36 PM|SETI@home|Requesting 1991 seconds of new work
9/4/2007 10:55:41 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:55:41 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:55:41 PM|SETI@home|Reason: requested by project
9/4/2007 10:55:41 PM|SETI@home|Deferring communication for 1 min 0 sec
9/4/2007 10:55:41 PM|SETI@home|Reason: no work from project
9/4/2007 10:56:41 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:56:41 PM|SETI@home|Requesting 3033 seconds of new work
9/4/2007 10:56:46 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:56:46 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:56:46 PM|SETI@home|Reason: requested by project
9/4/2007 10:56:46 PM|SETI@home|Deferring communication for 1 min 0 sec
9/4/2007 10:56:46 PM|SETI@home|Reason: no work from project
9/4/2007 10:57:46 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:57:46 PM|SETI@home|Requesting 4131 seconds of new work
9/4/2007 10:57:51 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:57:51 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:57:51 PM|SETI@home|Reason: requested by project
9/4/2007 10:57:51 PM|SETI@home|Deferring communication for 1 min 0 sec
9/4/2007 10:57:51 PM|SETI@home|Reason: no work from project
9/4/2007 10:58:51 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 10:58:51 PM|SETI@home|Requesting 5308 seconds of new work
9/4/2007 10:58:56 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 10:58:56 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 10:58:56 PM|SETI@home|Reason: requested by project
9/4/2007 10:58:56 PM|SETI@home|Deferring communication for 1 min 50 sec
9/4/2007 10:58:56 PM|SETI@home|Reason: no work from project
9/4/2007 11:00:51 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 11:00:51 PM|SETI@home|Requesting 7200 seconds of new work
9/4/2007 11:00:56 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 11:00:56 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 11:00:56 PM|SETI@home|Reason: requested by project
9/4/2007 11:00:56 PM|SETI@home|Deferring communication for 4 min 42 sec
9/4/2007 11:00:56 PM|SETI@home|Reason: no work from project
9/4/2007 11:05:41 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 11:05:41 PM|SETI@home|Requesting 11447 seconds of new work
9/4/2007 11:05:46 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 11:05:46 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 11:05:46 PM|SETI@home|Reason: requested by project
9/4/2007 11:05:46 PM|SETI@home|Deferring communication for 3 min 50 sec
9/4/2007 11:05:46 PM|SETI@home|Reason: no work from project
9/4/2007 11:09:41 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 11:09:41 PM|SETI@home|Requesting 14546 seconds of new work
9/4/2007 11:09:46 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 11:09:46 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 11:09:46 PM|SETI@home|Reason: requested by project
9/4/2007 11:09:46 PM|SETI@home|Deferring communication for 41 min 6 sec
9/4/2007 11:09:46 PM|SETI@home|Reason: no work from project
9/4/2007 11:34:33 PM|SETI@home|Computation for task 11mr07ae.25441.188260.3.5.176_2 finished
9/4/2007 11:34:33 PM|SETI@home|Starting 12fe07ab.32098.307684.15.5.18_1
9/4/2007 11:34:33 PM|SETI@home|Starting task 12fe07ab.32098.307684.15.5.18_1 using setiathome_enhanced version 527
9/4/2007 11:34:35 PM|SETI@home|[file_xfer] Started upload of file 11mr07ae.25441.188260.3.5.176_2_0
9/4/2007 11:34:39 PM|SETI@home|[file_xfer] Finished upload of file 11mr07ae.25441.188260.3.5.176_2_0
9/4/2007 11:34:39 PM|SETI@home|[file_xfer] Throughput 36349 bytes/sec
9/4/2007 11:44:31 PM|SETI@home|Computation for task 11mr07ab.10430.17250.6.5.175_1 finished
9/4/2007 11:44:33 PM|SETI@home|[file_xfer] Started upload of file 11mr07ab.10430.17250.6.5.175_1_0
9/4/2007 11:44:36 PM|SETI@home|[file_xfer] Finished upload of file 11mr07ab.10430.17250.6.5.175_1_0
9/4/2007 11:44:36 PM|SETI@home|[file_xfer] Throughput 34813 bytes/sec
9/4/2007 11:50:56 PM|SETI@home|Sending scheduler request: To fetch work
9/4/2007 11:50:56 PM|SETI@home|Requesting 30240 seconds of new work, and reporting 2 completed tasks
9/4/2007 11:51:01 PM|SETI@home|Scheduler RPC succeeded [server version 511]
9/4/2007 11:51:01 PM|SETI@home|Deferring communication for 11 sec
9/4/2007 11:51:01 PM|SETI@home|Reason: requested by project
9/4/2007 11:51:01 PM|SETI@home|Deferring communication for 56 min 47 sec
9/4/2007 11:51:01 PM|SETI@home|Reason: no work from project
9/5/2007 12:01:51 AM|SETI@home|Sending scheduler request: To fetch work
9/5/2007 12:01:51 AM|SETI@home|Requesting 30240 seconds of new work
9/5/2007 12:01:56 AM|SETI@home|Scheduler RPC succeeded [server version 511]
9/5/2007 12:01:56 AM|SETI@home|Deferring communication for 11 sec
9/5/2007 12:01:56 AM|SETI@home|Reason: requested by project
9/5/2007 12:01:56 AM|SETI@home|Deferring communication for 3 hr 27 min 5 sec
9/5/2007 12:01:56 AM|SETI@home|Reason: no work from project
