- Feb 5, 2010
- New Jersey
OK here is the situation. i have a small Lenovo pc and i wanted to use it as a media center pc but my tv is old and it only has a composite video in jack just like on the back of all vcrs. because of that i cannot at this time hook up the Lenovo pc to my tv so im currently using it in another room and simply sharing files to a pc that has a composite out on the video card. another words im sharing my entire desktop from the lenovo to this temporary media pc that is hooked up to my tv.
Ok now i will list the technical stuff that may be relevant:
Lenovo pc: windows 7 ultimate 64 bit sp1, linksys wireless G usb adapter. 2tb storage drive ntfs
Temporary media center pc: windows xp pro sp3, netgear wireless g pci adapter, 250gb storage drive ntfs
the folder on Lenovo pc desktop i am sharing fully with everyone on my lan (read, write, change) contains full length movies which i ripped from my own dvds and some i downloaded. 418 files totaling 378gb consisting of a mix of mkv, m4v, mp4, avi and mpg videos.
I have been puzzled by this sharing crap for weeks until today when i decided to try something and it happened to work.
here is the weird problem i encountered. If i share the entire folder with all of 418 files in it the temporary media center pc will only see 362 files. so because of this i went to my lenovo pc and made duplicate copies of the entire folder so now i have 836 files and half of them have a added " Copy." at the end of them as windows 7 adds that to files already in the folder so they are not overwritten. so now i go back to the temp media pc and notice that now the 362 files seen before increased to 726 files or something as i don't remember the exact # and totaling 600+ gigs. on the media pc i delete all of the files with "copy" in them and i go back to the lenovo pc and count and it shows 56 file that i was not able to delete from the temp media pc because they were not visible.
so i decided to split the 418 files into 2 folders with 215 in one and 203 in the other. and now i went to temp media pc and see that out of 215 only 190 are visible and out of 203 172 are visible and the total visible shared files stays the same at 362. so i go back to the Lenovo pc and split up those 2 folders into 4 folders containing these amounts 0 -D (111 files), E - L (104 files), M - S (109 files), T - Z (94 files). this time all files are shown but only if i split them up into smaller groups. WHY?
so now i would like a logical explanation why im not able to share the entire folder of 418 files and have the files visible on the shared pc. this really is weird.
