can you do that with big coolers? or the heavy coolers? it might be easy with a pull out MB tray but to install heavy heatsinks wouldn't it be advisable to install them first and then put the MB in the case? just makes things more simpler and easy.
do it any way you like, its a pain in the arse no matter what. That last push-pin never wants to go in and you have to literally put you whole body weight on it to push it in. Only easy way is to buy a bolt-thru kit.
