- Jan 22, 2003
- Durham, NC
Will a gig of the Hynix / A-DATA PC4200 do 1T?
Lifthanger said:Cheep
I was lucky this time. Adata was usually 130€ per stick, just like Kingmax, but there its only 107€.. So I've got them for 219,30€ shipping included.
Now beat this
Now beat this
K4mui said:Lol, one "e" missing in "cheep"
But I'm still not sure wether to buy them or get some low latency- modules, just read in another forum in a thread of mine that low timings are better than high frequencies... argh, getting crazy! (hmm, should I get both? Could try it and send it back (in Germany we have a law allowing this))
Its the same thing i have from newegg adata viesta ddr500 and mine fly.But they seem to have daul channel kits now.The only difference is in the name komusa sells them under hyperram. And they give you the red heatspreaders if you order the aluminum ones.Im not sure what color you get if you order the copper heatspreaders.BUT ITS THE SAME THING.BELIEVE ME I HAVE THE PC 4000 FROM NEWEGG AND THEY DO 270FSB AND PROLLY HIGHER ITS JUST MY CPU WONT LET GET THAT HIGH.Dethshaft said:so, what are these then? http://www.buyaib.com/avi10pc50nou.html
I am confused between Vitesta and theregular stuff on the komusa website
Lifthanger said:I think rather controversy about toms hardware. some things were really helpful, while others are not. (They made me buy a 9600 XT.. damn I was dumb).
I'll tell you when my memory arrives.
situman, 400$ for 2*512 ?
I just asked because I'm originally from Karlsruhe, des kannsch mir glaube.
lol
gigabit said:Its the same thing i have from newegg adata viesta ddr500 and mine fly.But they seem to have daul channel kits now.The only difference is in the name komusa sells them under hyperram. And they give you the red heatspreaders if you order the aluminum ones.Im not sure what color you get if you order the copper heatspreaders.BUT ITS THE SAME THING.BELIEVE ME I HAVE THE PC 4000 FROM NEWEGG AND THEY DO 270FSB AND PROLLY HIGHER ITS JUST MY CPU WONT LET GET THAT HIGH.
