Hi all,
I'm relatively new to posting in these forums, but I've been actively reading them for some time. I recently overclocked my processor (Athlon T-bird 1.2 266 AYHJA-9 oc'd to 1.37 10x multiplier on a 137 fsb) and with the temps I was getting, I knew I needed some cooling help. Even at default speeds, I was having a wee bit of a heat problem with my processor.
For my HSF, I had gotten a (hangs his head) Coolermaster DP5-6I11A. On my case, I had 1 80mm fan in the front at the base as an intake, and in the rear were 2 80mm fans (1 in the power supply) that were performing exhaust duties. At default speeds (9.5x133), with my case closed up, I was getting idle temps of 46.4c (115.5f) and load temps of 49.1c (120.4f). After going through some of the cooling tips on this site, and reading many many posts, I decided the time had come to take some action.
The first thing I did was cut out a hole in two of my 5.25" drive bays to accomodate another 80mm fan. I then hung a small "L" bracket under the power supply (directly over the HSF) blowing down at a slight angle (angled toward the back of the case.) Finally, I cut the metal grille surrounding the lower intake fan, and increased the size and number of the holes in the front plastic cover. Regardless of which combinations of intake and exhaust that I tried, the temps barely budged (I lost 1c from idle and load no matter how I set the airflow of the fans.) I removed the side of the case and got a more noticable drop (40.9c idle, 47.4 load).
The highest I could overclock stable was (and still seems to be) 1.37, and my temps at this speed (10x173) were 41.4c idle and 48.9c load. This was, of course, with my case cover off. I didn't want to leave my case open, and knew that it was time for me to spend a little coin. Not having much to spend, I opted for the "Copperman" from 1CoolPC (Vantec CCK-6035D) and a new 80mm case fan (Sunon 50.6 cfm) along with a tube of ASII. My mainboard is a FIC AZ-11EA, so the Alpha was unfortunately, not an option for me. Well, my parts came, and I began the installation. I cleaned all the old thermal grease (generic) off the cpu, and then applied ASII as per the instructions on their website (substituting an old healthcare card in place of the credit card suggested ). I then replaced the fan I added to the drive bays with the new sunon fan (as an intake, seems to work better that way.) Well, I'm happy to say that my case is closed up and I'm now getting temps of 39.4c at idle and... 41.9c at Load!! This is at 1.37, after a 3-hour long flight in FS2002! I can finally keep my case closed AND not have to constantly worry about the heat!
One other thing to note, I added a second power supply (an old 235 watt AT) to the top of the case (outside it, actually ) and I drilled a hole in the top of the case to run the wires into it. The old switch is run to the bottom 5.25 drive bay that the extra intake fan is in. I got the tips for adding the extra power supply, and how to use drive bays for extra fans, right on this site!
So to those of you (like myself) that are new to this site, make sure you read all that you can find here, and take in all the info that you can. Most of these folks really know what they're talking about. And to those of you who regularly contribute to this site, and help those with questions, a very hearty thank-you.
Sincerely,
GeorgeT
System Specs:
AMD Athlon T-Bird 1.2 (AYHJA-9 Week 23, 2001) @ 1.37 (10x137)
FIC AZ-11EA Rev 2.1 (BIOS VDC-47)
384 MB PC-133 Micron RAM
VisionTek Xstasy GeForce 3 Ti200 @ 210/430
Enlight 7237 Case (300w ps)
Vantec CCK-6035D "Copperman" HSF
One other thing to note, the additional power supply only controls the "extra" fans, and all wires in the case have been bundled together (using black electrical tape) and routed neatly (as neatly as I could get it ) and all this has been done since adding the first fan to the 5.25 bay. Ok, I think I covered everything. Thanks for listening, and thanks for all the information I've learned here. Oh, and sorry for the long-windedness, I can be that way sometimes... ok, pretty often!
-GeorgeT
[edited for a typo in "plastic"... forgot the "L" ]
Sincerely,
GeorgeT
System Specs:
-GeorgeT
