I've never heard of them either. Looking around a bit, I wouldn't trust it personally. Not when there aren't any reviews / tests at all and it's a totally unknown company as well.
I Completely understand what your saying. I'm just curious cause i already have it, claims to be 875, and the machine only needs about 650 to 700. Don't have pics today, Will grab some tomorrow.
It's hard to say for sure after looking at their website.
http://kdmpower.com/
It looks they make some units that are 80+ Bronze. You might check the model number against their web site and see what the specs are. If you find it's one of the 80+ Bronze units then I'd say it definitely worth trying anyway.
Model # is KDM-X8875C-875W
Attempting to do a site lookup shows nothing. PSU doesn't even exist on their site. I do have a spec sheet from their eBay listing though.
SPECIFICATION
Output Power: 875 Watt
Input Voltag: 88 -264 Volts Ac
Frequency: 60 / 50 Hz
Temperature Range
Operating: 0°C ~ +50°C on Full Load;
Storage & Shipping: -20°C ~ +80°C
Humidity: 5 ~ 90% on Operating, 5 ~ 95% on Storage
Dielectric Withstand: Primary Frame Ground 1800V AC for 1 Second
MTBF: 100,000 Hours on Maximum Load at +25°C
Rise time: Less than 20ms
Hold-up Time: 17ms Minimum at Nominal Input Voltage
Output
Voltage +5V +12V1 +12V2 -12V +3.3V +5V-SB
Current 25A 28A 28A 0.5A 25A 2.0A
Do not see an 80%+ on it. I'm a little interested if the PSU can even slightly do what it says.
