- Feb 25, 2003
- Charleston, SC
Anybody has any thoughts about these fans? The specifications from Newegg.com look good...
Specifications:
Dimensions: 120 x 120 x 25 mm
Bearing Type: 2 Ball Bearing
Nominal Speed(RPM): 2000
Max Air Flow(CFM): 79.14
Rated Voltage: 12V
Connector: 4 Pin
Noise(dBA): 30
Power: 2.83W
Are these as good as the Panaflo(s)?
Specifications:
Rated Voltage: 12V
Connector: 4 Pin
Noise(dBA): 30
Power: 2.83W
