I have a question about this pump, I am running a external water cooling setup and in need of a new pump this is the same style as my last pump just stronger.
Under the specs it says
Maximum Flow Rate: 17.4L/min (4.6 gal/min) @ 12V, 22.3L/min (5.9 gal/min) @ 24V
Maximum Head Pressure: 5.1m (16.8ft) @ 12V, 5.8m (19ft) @ 24V
Motor: Brushless DC, electronically commutated, spherical motor
Expected Lifetime: 50,000 hrs. MTBF (5.7 years)
Power: 8-24VDC, 3-55W, 0.13-2.1A
Startup Voltage: 9 to 13.2 VDC
Maximum System Pressure: 3.5 kgf/cm2 (50 PSI)
Maximum Temperature: 60°C (140°F)
Electrical Connector: 4-pin Molex power supply connection + 3-pin (single lead) tach
Hose Connections: 13mm (1/2") ID hose barbs
Wetted Materials: PPO, Carbon/Allumina Ceramic, EPDM or Viton, 316 SS
Noise: Less than 40dBA
Weight: 862g (1.9lbs)
I admit I do not know much about voltages but how do I know if connecting a molex is providing 24v and not just 12v to the pump. I have a molex AC adapter it is this model
Model: CS-1205000
Input: 100-240VAC 50/60Hz 1.5A
Output: Standard 4 Pin Power Connector
12 V DC at up to 5A draw
Model: CS-1205000
