- Jul 27, 2007
Just curious what the masses here are using and what you guys suggest? I don't want to break the bank on one, but I want a good, soild, and reliable switch. It needs to be USB with DVI. I had one in the past that used a button on the keyboard to switch between devices, which was ok. I see some of the switches physically have a button on the unit that you can use to switch between devices, that's fine as well. The only other thing I can think of that I would like is for the unit to be fast. I've read reviews on a few different models and it seems like there is a "lengthy" delay when switching from device to device.
Budget wise I'd like to not spend more then $75 on one. If possible to get a 4 port in that price range that would be a bonus, but I only NEED a 2 port. Also, audio isn't a big deal.
Thanks,
-RYknow
Thanks,
-RYknow
