- Nov 18, 2008
- Northwest Ohio
I can't log on the folding forums to post up, but something doesn't work right(unless that is how it's supposed to work)
LAGOUSTE
FOLDING
LAGOUSTE
Code:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\THEBEAST>cd"\
'cd"\' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\THEBEAST>cd\ dist\win32\
The system cannot find the path specified.
C:\Users\THEBEAST>cd\fold\langouste3
C:\FOLD>dir
Volume in drive C has no label.
Volume Serial Number is BAC2-5CF6
Directory of C:\FOLD
01/25/2011 09:50 AM <DIR> .
01/25/2011 09:50 AM <DIR> ..
03/12/2010 11:30 AM <DIR> CoreTemp64
01/25/2011 09:52 AM <DIR> CPU
04/03/2010 03:10 AM 3,497 cpu-3gpu's.hfm
03/12/2010 11:30 AM <DIR> CPUZ
01/25/2011 01:57 AM <DIR> GPU 0
01/25/2011 01:57 AM <DIR> GPU 1
01/25/2011 08:12 AM 6,002 HFM Config 7 workers.hfm
01/25/2011 09:50 AM <DIR> langouste
03/12/2010 10:39 PM <DIR> Prime95
03/12/2010 11:38 AM <DIR> Realtemp
01/16/2011 07:43 PM <DIR> todd netbook
03/12/2010 11:40 AM <DIR> trayit_4_6_5_5
2 File(s) 9,499 bytes
12 Dir(s) 585,357,373,440 bytes free
C:\FOLD>cd\fold\langouste
C:\FOLD\langouste>cd\fold\langouste\dist\win32
C:\FOLD\langouste\dist\win32>langouste3-0.15.6.exe -1 8880
langouste3-0.15.6.exe: invalid option -- 1
Usage:
langouste3-0.15.6.exe -l <port> [-v] [-L <logfile>] [-r <rate>] [-x] [-d
] [-C]
langouste3-0.15.6.exe -h
langouste3-0.15.6.exe -V
Regular options:
-l <port> listen on <port>
-v increase log verbosity; can be specified multiple times
-L <logfile> write log to <logfile>
-r <rate> limit upload data transfer rate to <rate> bytes
per second
-h display this help and exit
-V output version information and exit
Expert options:
-x drop connections related to receiving new WU
-d be dumb
-C do not perform sanity checks
C:\FOLD\langouste\dist\win32>langouste3-0.15.6.exe -l 8880
Tue Jan 25 09:59:18 2011 Langouste3 0.15.6 (compiled Mon Aug 30 11:01:54 MDT 201
0 by kszysiu@tentacle)
Tue Jan 25 09:59:18 2011 Langouste3 comes with ABSOLUTELY NO WARRANTY; for detai
ls
Tue Jan 25 09:59:18 2011 see `COPYING.txt' file located in source directory
Tue Jan 25 09:59:18 2011 Default Langouste helper temp directory: C:\Users\THEBE
AST\AppData\Local\Temp\langouste-THEBEAST\
Tue Jan 25 09:59:18 2011 Listening on 127.0.0.1:8880
Tue Jan 25 10:08:01 2011 Signal 2 received
Tue Jan 25 10:08:01 2011 Listen socket closed.
Tue Jan 25 10:08:01 2011 No more active connections. Exiting.
Tue Jan 25 10:08:01 2011 Bye.
C:\FOLD\langouste\dist\win32>langouste3-0.15.6.exe -l 8880 -r 256000
Tue Jan 25 10:08:58 2011 Langouste3 0.15.6 (compiled Mon Aug 30 11:01:54 MDT 201
Tue Jan 25 10:08:58 2011 Langouste3 comes with ABSOLUTELY NO WARRANTY; for detai
ls
Tue Jan 25 10:08:58 2011 see `COPYING.txt' file located in source directory
Tue Jan 25 10:08:58 2011 Default Langouste helper temp directory: C:\Users\THEBE
Tue Jan 25 10:08:58 2011 Ratelimit: Output rate: 256000 bytes/s (250.00 kBps)
Tue Jan 25 10:08:58 2011 Listening on 127.0.0.1:8880
Wed Jan 26 08:11:57 2011 Accepted connection from: 127.0.0.1:52022
Wed Jan 26 08:11:57 2011 PID for socket: 7244
Wed Jan 26 08:11:57 2011 PID 7244: issending: 0
Wed Jan 26 08:11:57 2011 ===> PID 7244 is (most likely) contacting WU server, co
ntent length: 100198447
Wed Jan 26 08:11:57 2011 ===> Helper pid: -1
Wed Jan 26 08:11:57 2011 FahCore_15.exe (PID 10728) appears to belong to another
client, continuing.
Wed Jan 26 08:11:57 2011 FahCore_11.exe (PID 10992) appears to belong to another
client, continuing.
Wed Jan 26 08:11:57 2011 ===> PID 7244: numcores: 0
Wed Jan 26 08:11:57 2011 ===> now: 1296047517, last helper launched at: 0
Wed Jan 26 08:11:57 2011 ===> Launching helper: 'C:\FOLD\CPU\langouste-helper.ba
t' (exe name: 'C:\FOLD\CPU\FAH_CPU.exe')...
Wed Jan 26 08:11:57 2011 ===> Forked 0x000088
Wed Jan 26 08:11:57 2011 (0) Local: received 125 bytes, sent 0 bytes
Wed Jan 26 08:11:57 2011 Accepted connection from: 127.0.0.1:52023
client, continuing.
client, continuing.
Wed Jan 26 08:11:57 2011 ===> now: 1296047517, last helper launched at: 12960475
17
Wed Jan 26 08:11:57 2011 ===> WARNING: can only launch one helper in 2 minutes (
per client)
Wed Jan 26 08:11:57 2011 (0) Local: received 121 bytes, sent 0 bytes
Wed Jan 26 08:11:57 2011 Accepted connection from: 127.0.0.1:52024
client, continuing.
client, continuing.
17
per client)
Wed Jan 26 08:11:57 2011 Accepted connection from: 127.0.0.1:52025
client, continuing.
client, continuing.
17
per client)
Wed Jan 26 08:11:57 2011 Accepted connection from: 127.0.0.1:52026
client, continuing.
client, continuing.
17
per client)
Wed Jan 26 08:11:57 2011 Accepted connection from: 127.0.0.1:52027
client, continuing.
client, continuing.
17
per client)
23 File(s) copied
launching asynchronous part
Wed Jan 26 08:12:15 2011 Accepted connection from: 127.0.0.1:52028
Wed Jan 26 08:12:15 2011 PID for socket: 7244
Wed Jan 26 08:12:15 2011 PID 7244: issending: 0
Wed Jan 26 08:12:15 2011 ===> PID 7244 is contacting main assignment server
Wed Jan 26 08:12:15 2011 (0) resolving 'assign.stanford.edu:8080'
Wed Jan 26 08:12:15 2011 (0) Connecting to: 171.67.108.200:8080
Wed Jan 26 08:12:15 2011 (0) Connected.
Wed Jan 26 08:12:15 2011 (0) Local connection closed (bsize: 0).
Wed Jan 26 08:12:15 2011 (0) Local: received 559 bytes, sent 396 bytes
Wed Jan 26 08:12:15 2011 (0) Remote: received 396 bytes, sent 559 bytes
Wed Jan 26 08:12:15 2011 Accepted connection from: 127.0.0.1:52030
Wed Jan 26 08:12:15 2011 ===> PID 7244 is (most likely) contacting WU server, co
ntent length: 512
Wed Jan 26 08:12:15 2011 (0) resolving '130.237.232.141:8080'
Wed Jan 26 08:12:15 2011 (0) Connecting to: 130.237.232.141:8080
Wed Jan 26 08:13:09 2011 Accepted connection from: 127.0.0.1:52040
Wed Jan 26 08:13:09 2011 PID for socket: 9372
Wed Jan 26 08:13:09 2011 PID 9372: issending: 1
Wed Jan 26 08:13:09 2011 (1) resolving '130.237.232.141:8080'
Wed Jan 26 08:13:09 2011 (1) Connecting to: 130.237.232.141:8080
Wed Jan 26 08:13:09 2011 (1) Connected.
Wed Jan 26 08:14:02 2011 (0) Local connection closed (bsize: 0).
Wed Jan 26 08:14:02 2011 (0) Local: received 631 bytes, sent 24870954 bytes
Wed Jan 26 08:14:02 2011 (0) Remote: received 24870954 bytes, sent 631 bytes
Wed Jan 26 08:14:02 2011 Accepted connection from: 127.0.0.1:52047
Wed Jan 26 08:14:02 2011 PID for socket: 7244
Wed Jan 26 08:14:02 2011 PID 7244: issending: 0
Wed Jan 26 08:14:02 2011 ===> PID 7244 is (most likely) contacting WU server, co
Wed Jan 26 08:14:02 2011 ===> Helper pid: 9372
Wed Jan 26 08:14:02 2011 FahCore_15.exe (PID 10728) appears to belong to another
client, continuing.
Wed Jan 26 08:14:02 2011 FahCore_11.exe (PID 10992) appears to belong to another
client, continuing.
Wed Jan 26 08:14:02 2011 ===> PID 7244: numcores: 0
Wed Jan 26 08:14:02 2011 ===> Helper (pid 9372) already running
Wed Jan 26 08:14:02 2011 ===> If you're sure that's not the case, please remove
C:\Users\THEBEAST\AppData\Local\Temp\fah\f1
Wed Jan 26 08:14:02 2011 (0) Local: received 125 bytes, sent 0 bytes
Wed Jan 26 08:14:02 2011 Accepted connection from: 127.0.0.1:52048
client, continuing.
client, continuing.
Wed Jan 26 08:14:02 2011 (0) Local: received 121 bytes, sent 0 bytes
Wed Jan 26 08:14:02 2011 Accepted connection from: 127.0.0.1:52049
client, continuing.
client, continuing.
Wed Jan 26 08:14:02 2011 Accepted connection from: 127.0.0.1:52050
client, continuing.
client, continuing.
Wed Jan 26 08:32:26 2011 (1) Local connection closed (bsize: 0).
Wed Jan 26 08:32:26 2011 (1) Local: received 100198572 bytes, sent 636 bytes
Wed Jan 26 08:32:26 2011 (1) Remote: received 636 bytes, sent 100198572 bytes
Wed Jan 26 08:32:26 2011 (1) Ratelimit: sent 100198572 byte(s) in 1156.835 secon
ds, 86614 Bps (84.58 kBps)
FOLDING
Code:
[03:47:24] Completed 212500 out of 250000 steps (85%)
[04:26:29] Completed 215000 out of 250000 steps (86%)
[05:05:30] Completed 217500 out of 250000 steps (87%)
[05:43:35] Completed 220000 out of 250000 steps (88%)
[06:21:20] Completed 222500 out of 250000 steps (89%)
[06:57:36] Completed 225000 out of 250000 steps (90%)
[07:34:21] Completed 227500 out of 250000 steps (91%)
[08:14:52] Completed 230000 out of 250000 steps (92%)
[08:50:34] Completed 232500 out of 250000 steps (93%)
[09:09:15] - Autosending finished units... [January 26 09:09:15 UTC]
[09:09:15] Trying to send all finished work units
[09:09:15] + No unsent completed units remaining.
[09:09:15] - Autosend completed
[09:26:38] Completed 235000 out of 250000 steps (94%)
[10:03:12] Completed 237500 out of 250000 steps (95%)
[10:40:48] Completed 240000 out of 250000 steps (96%)
[11:18:19] Completed 242500 out of 250000 steps (97%)
[11:55:55] Completed 245000 out of 250000 steps (98%)
[12:33:28] Completed 247500 out of 250000 steps (99%)
[13:11:02] Completed 250000 out of 250000 steps (100%)
[13:11:17] DynamicWrapper: Finished Work Unit: sleep=10000
[13:11:27]
[13:11:27] Finished Work Unit:
[13:11:27] - Reading up to 52713120 from "work/wudata_07.trr": Read 52713120
[13:11:28] trr file hash check passed.
[13:11:28] - Reading up to 47105148 from "work/wudata_07.xtc": Read 47105148
[13:11:28] xtc file hash check passed.
[13:11:28] edr file hash check passed.
[13:11:28] logfile size: 211727
[13:11:28] Leaving Run
[13:11:31] - Writing 100197935 bytes of core data to disk...
[13:11:33] ... Done.
[13:11:52] - Shutting down core
[13:11:52]
[13:11:52] Folding@home Core Shutdown: FINISHED_UNIT
[13:11:57] CoreStatus = 64 (100)
[13:11:57] Unit 7 finished with 57 percent of time to deadline remaining.
[13:11:57] Updated performance fraction: 0.664738
[13:11:57] Sending work to server
[13:11:57] Project: 6900 (Run 4, Clone 23, Gen 20)
[13:11:57] + Attempting to send results [January 26 13:11:57 UTC]
[13:11:57] - Reading file work/wuresults_07.dat from core
[13:11:57] (Read 100197935 bytes from disk)
[13:11:57] Connecting to http://130.237.232.141:8080/
[13:11:57] - Couldn't send HTTP request to server
[13:11:57] + Could not connect to Work Server (results)
[13:11:57] (130.237.232.141:8080)
[13:11:57] + Retrying using alternative port
[13:11:57] Connecting to http://130.237.232.141:80/
[13:11:57] (130.237.232.141:80)
[13:11:57] - Error: Could not transmit unit 07 (completed January 26) to work se
rver.
[13:11:57] - 1 failed uploads of this unit.
[13:11:57] Keeping unit 07 in queue.
[13:11:57] Trying to send all finished work units
rver.
[13:11:57] - 2 failed uploads of this unit.
[13:11:57] Connecting to http://130.237.165.141:8080/
[13:11:57] (130.237.165.141:8080)
[13:11:57] Connecting to http://130.237.165.141:80/
[13:11:57] (130.237.165.141:80)
[13:11:58] Could not transmit unit 07 to Collection server; keeping in queue.
[13:11:58] + Sent 0 of 1 completed units to the server
[13:11:58] - Preparing to get new work unit...
[13:11:58] Cleaning up work directory
[13:12:15] + Attempting to get work packet
[13:12:15] Passkey found
[13:12:15] - Will indicate memory of 6135 MB
[13:12:15] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[13:12:15] - Connecting to assignment server
[13:12:15] Connecting to http://assign.stanford.edu:8080/
[13:12:15] Posted data.
[13:12:15] Initial: ED82; - Successful: assigned to (130.237.232.141).
[13:12:15] + News From Folding@Home: Welcome to Folding@Home
[13:12:15] Loaded queue successfully.
[13:12:15] Sent data
[13:12:15] Connecting to http://130.237.232.141:8080/
[13:12:23] Posted data.
[13:12:23] Initial: 0000; - Receiving payload (expected size: 24870300)
[13:14:02] - Downloaded at ~245 kB/s
[13:14:02] - Averaged speed for that direction ~553 kB/s
[13:14:02] + Received work.
[13:14:02] Trying to send all finished work units
[13:14:02] Project: 6900 (Run 4, Clone 23, Gen 20)
[13:14:02] + Attempting to send results [January 26 13:14:02 UTC]
[13:14:02] - Reading file work/wuresults_07.dat from core
[13:14:02] (Read 100197935 bytes from disk)
[13:14:02] Connecting to http://130.237.232.141:8080/
[13:14:02] - Couldn't send HTTP request to server
[13:14:02] + Could not connect to Work Server (results)
[13:14:02] (130.237.232.141:8080)
[13:14:02] + Retrying using alternative port
[13:14:02] Connecting to http://130.237.232.141:80/
[13:14:02] (130.237.232.141:80)
[13:14:02] - Error: Could not transmit unit 07 (completed January 26) to work se
rver.
[13:14:02] - 3 failed uploads of this unit.
[13:14:02] Connecting to http://130.237.165.141:8080/
[13:14:02] (130.237.165.141:8080)
[13:14:02] Connecting to http://130.237.165.141:80/
[13:14:02] (130.237.165.141:80)
[13:14:02] Could not transmit unit 07 to Collection server; keeping in queue.
[13:14:02] + Sent 0 of 1 completed units to the server
[13:14:02] + Closed connections
[13:14:02]
[13:14:02] + Processing work unit
[13:14:02] Core required: FahCore_a3.exe
[13:14:02] Core found.
[13:14:02] Working on queue slot 08 [January 26 13:14:02 UTC]
[13:14:02] + Working ...
[13:14:02] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 8 -che
ckpoint 15 -verbose -lifeline 7244 -version 630'
[13:14:02]
[13:14:02] *------------------------------*
[13:14:02] Folding@Home Gromacs SMP Core
[13:14:02] Version 2.22 (Mar 12, 2010)
[13:14:02]
[13:14:02] Preparing to commence simulation
[13:14:02] - Looking at optimizations...
[13:14:02] - Created dyn
[13:14:02] - Files status OK
[13:14:06] - Expanded 24869788 -> 30796293 (decompressed 123.8 percent)
[13:14:06] Called DecompressByteArray: compressed_data_size=24869788 data_size=3
0796293, decompressed_data_size=30796293 diff=0
[13:14:07] - Digital signature verified
[13:14:07]
[13:14:07] Project: 6900 (Run 11, Clone 10, Gen 24)
[13:14:07]
[13:14:07] Assembly optimizations on if available.
[13:14:07] Entering M.D.
[13:14:15] Completed 0 out of 250000 steps (0%)
[13:52:05] Completed 2500 out of 250000 steps (1%)
