- May 27, 2002
- Austin, TX
I've got a Dell B130 laptop with a cd burner / dvd drive. I've been wanting to a install a DVD burner in it's place, but it from what I can collect, the hard drive and optical drive are master and slave on the same IDE channel. Why this is the case I don't know, but it seems to be common practice on many laptops. I've never had a DVD burner on this laptop, but it seems other laptops I've used with this configuration end up burning DVD's extremely slow. You can tell the program to burn at the fastest speed, but it'll only go as fast as it can get the data. In this case it wouldn't even be worth it.
Now I've taken a 3.5" IDE to USB 2.0 external enclosure i had and connected the 5.25" 18x DVD burner from my desktop as a makeshift external drive and it works well. I can burn at 4x with no issues. I have not tried faster but 4x isenough for me since I don't like coasters. It's bulky and ghetto looking but it works. I'd like to get the internal drive if I can though since it's simply less to carry around.
Those of you with internal DVD burners as a slave to the hard drive on the same channel, are burn speeds acceptable or are these just isolated incidents that I experienced ?
