So it's restarting randomly? I'm not real clear what the problem is; I know you can disable ASUS Express Gate from the BIOS. It should be quick to locate.
1. Bios is configured to automatically launch express gate upon boot
2. Your laptop is crashing/restarting
If you haven't already, in computer properties go to the advanced tab, then the startup & recovery section and click settings, then under "system failure" uncheck the box for automatically restart. If you are getting a blue screen, that will make it stay on the screen so you can see what its saying.
