So I've recently just built my new rig (specs in sig are correct, minus the 570 which should arrive tomorrow. I have an old radeon x1800 as a placeholder), and I'm looking to start OCing my i7 950. I've started by following miahallen's updated guide over at techreaction, but I'm having a tough time getting this going. I'm at step 1, Maximze Bclock & Uncore Frequency. Here's what I've done so far:
My goals for the OC are Bclock = 200Mhz, CPU Freq = 4.2Ghz, Memory Speed = DDR3-1600(uncore @ 3200Mhz).
1. Set CPU Clock Ratio to x15
2. Set CPU Uncore Frequency to x16
3. Set Memory Frequency to 6
4. Set bclock to 150
5. Set IOH Vcore to 1.1v
Save & Exit then boot to desktop. Run OCCT for a minute or two (CPU:LINPACK). It's stable so I reboot and enter bios.
6. Set bclock to 160
Save & Exit. Here's where I'm having problems; my computer restarts, but the monitor stays blank. All the lights are lit up on the mobo and all the fans are running, but it doesn't beep and the monitor stays off. So after giving it a few minutes I press the clear CMOS button and restart the computer. I go back into bios and give CPU VTT Voltage +.025v and Save & Exit. Same thing as before - mobo lights up, fans run, but again no beep and monitor stays off. I try giving CPU VTT Voltage up to +.1v (1.3v total) and still nothing happens.
So whats going on? I thought any x58 mobo over $200 and any i7 CPU could do 4ghz with ease (200x20 and call it a day), yet this board can't even get a bclock over 150?
