- Jan 10, 2012
- Thread Starter
- #21
says 75.9%, what's that mean?
I hit 1846 @stock. Not much of a difference, only 5£ with 200MHz/530MHz difference.
It seems the CPU is the bottleneck, lol!
Can't do much about it, I've hit the BCLK wall...
Might try with the memory, but I doubt that I can do any better. Will try anyway.
Does that say 3.024 Vcore?
@Caddi
75% ASIC is alright... Not the hand picked cherries or anything.
Higher % usually means a better card for OC torture IIRC
Though I don't believe it. My 7850 has 84.6% ASIC quality and it just sucks for stability when on a high OC
Yep, ASIC doesn't always reflect the OC capabilities...
The 280x I use now has a "low" 70% ASIC, but is Gaming/Benching stable@1200MHz+ on the core and 1950MHz on the memory.
What sucks id that even if the Dual-X is voltage unlocked, it has a HUGE vdrop: when [email protected], voltage drops to 1.2v on load...
Scout you may not know C/D that well to suggest volt modding his card. I can only imagine what kind of voltage he will try if he did that.
What does that dialog box tells you it means?says 75.9%, what's that mean?
poor thing is on air.
after the bios flash disaster with the other card I may just have to stop that stuff.
Vdrop is driven by hardware (vrm's to be precise), and as there is no llc calibration/hack onbthe 280x, only way to fix it is volt modding the card.
