- Jan 1, 2008
- Colorado Springs, CO
So I am almost done gathering parts for my first custom loop, all I need to buy is compression fittings at this point and spend some time cleaning the components.
For compression fittings, I need 3/4 OD, 1/2 ID size fittings for soft tubing, and 5 straight, and one 90° fitting. What brands are good and cheap?
Parts gathered so far:
Black Ice Stealth 140.2 rad
Noctua iPPC-3000 fans (x2 push only, due to case
D5 fixed speed w/ swiftech top
Swiftech micro res v.2
Swiftech XT(?) Block - not super sure on this one, bought it used and it is an older model, w/ a metal top
Have some fund-age finally to pickup the fittings, but $50 counting shipping is pushing it. What do you all think for decent cheap compression fittings?
Depending on the cooling results of the system, I may add a rear 120.1 rad to help tame the FX-8320e. Considering I had it running easily at 4.5ghz w/ an old H80 AIO unit, I figure this setup will yield better results.
