- Feb 12, 2010
Hi there, I'm building a shiny new i7 PC soon, and just wanted to get some input.
Primarily I'm looking at 3 Motherboards
ASUS P6T Deluxe V2
GIGABYTE GA-X58A-UD7
GIGABYTE GA-X58A-UD3R
I'm leaning towards the GIGABYTE GA-X58A-UD7 at the moment, but have some questions.
So, I've been looking around and ASUS P6T Deluxe V2 seems to have some very promising reviews, however it lacks Sata III and USB 3.0
The two GIGABYTE boards have the exact same specs as far as I can tell, but I have some concerns:
First, is one substantially better for OCing between the two? .2 or so GHz difference or anything like that isn't that important to me, but .5 would be.
Second, can anybody find any REAL differences between these boards?
Third, I've heard some stuff online about SLI, USB 3.0 and SATA III not getting along very well at all. Pretty much I've been hearing, that if you use SSUSB for USB 3.0, then in SLI you forfeit your 16x 16x (What I'd be using) with 8x 8x which is unacceptable to me.
These boards are $150 difference in price, which is insane, but I'd be willing to pay if the UD7 was significantly better for OCing, or UD7 didn't have those USB/SLI issues while UD3R, or w/e. And for the ASUS, is forfeiting the SATA/USB worth it, when I can get a seemingly better board for $100 less?
ASUS P6T Deluxe V2
