- Oct 31, 2002
- Thread Starter
- #21
Just got my xspc raystorm, swiftech low profile black fittings and 10ft primochill in the mail. the primochill is.. less stellar than other cheap stuff ive used in the past, masterkleer comes to mind but cant beat 10ft for $5 on clearance special at ncix!
one of these days, with my very diverse watercooling experience, i might pick up some tygon lol...
modifying the swiftech for gpu use will simply involve drilling the retention plate for the 5850 pattern. very simple. not sure if ill use the stock backplate or not. if i could adapt it to work with some m3 screws it might work but i think they are m1.5 or somthing rediculous. i do have my lga 775 scythe backing plate i can also modify if need be.
I posted in amd gpus but not sure if the ram on this car needs a heatspreader or not. there was a 2mm thick thermal pad connecting it to the stock cooling frame. im sure that did SOMETHING but would free air around the chipsets be as effective?
I was hoping i had some aluminum around to fabricate a heat spreader but it looks like i do not. though if its needed, i could make heat spreaders pretty easily i should think.
building this up though, first thing that is ditched is stock case screws. im sick and tired of dealing with philips in my computers. all the case stuff that accepts metric screws is getting upgraded to hex cap screws. after enjoying these screws for years in rc, it is a cheap and simple "servicability" upgrade that no one will ever see or care about lol.
