- Sep 14, 2007
- Florida, US
I have been away from the windows world for about 3-4 years... Whats a good light and good antivirus? same for firewall?
Avira AntiVir Personal 12.0.0.1167
Disconnect Internet connection. Double click on Setup.exe to install the program.
Ignore Avira's warnings to uninstall Comodo Firewall or similar programs which intercept phone-home attempts.
UNCHECK everything when asked to install Avira Toolbars.
Allow the configuration wizard to keep the default extended threat categories. [Do not Select All.]
(UNCHECK: Application (APPL), Fraudulent Software, Games, Jokes, Programs that violate the private domain, and Unusual runtime compression.)
*ABORT any update process when it automatically pops up!* (If you haven't disconnected Internet connection as instructed above.)
Setup the program before connecting to the internet:
Subscription to new virus definitions for this program is renewed automatically through product updates. It is not renewed through virus definition updates. If product updates are disabled in order to prevent installation of a newer version of the program, download the latest key file from
[url]http://dl2.avgate.net/down/windows/hbedv.key[/url]
and either copy it to
C:\Program Files\Avira\AntiVir Desktop
and restart or go to Help > License management > click on the blue hbedv.key link > browse to the new downloaded hbedv.key > Open.
Options:
C:\Program Files\Avira\AntiVir Desktop\avcenter.exe
System Scanner (on left) > Configuration (Right middle part of the window) > Yes > UNCHECK: Follow symbolic links (middle right) > System Scanner > Scan > Action for concerning files >
Set for Automatic, Primary action: Ignore if wanting to just scan folders and get a scan report without deleting files or being prompted what to do if virii/malware is found.
> Update > Product Update > Do not download product updates. [This option is only for Avira Antivir product updates (Antivirus definitions will still be downloaded automatically.) Product updates should be downloaded manually by going to Update > Start product update... because they may affect the Windows operating system. They should preferably be downloaded only *after* imaging the operating system partition so that if they cause problems you can reimage back to the state before product updates were installed.]
> General > Security >
Disable being notified every time USB drive has an AUTORUN.INF file:
UNCHECK: Block autostart function
> General > Alerts > UNCHECK everything except Dial-up connection is used
Set Avira Free Antivirus to Always Ahow in Windows Taskbar.
To disable Notifier nag screen: Windows 2000/XP Control Panel > Administrative Tools [in Windows 7, click on System and Security first] > Local Security Policy > Right click on Software Restriction Policies > Create New Policies > Right click on Additional Rules > New Path Rule... > Browse... to the path of avnotify.exe default is
C:\Program Files\Avira\AntiVir Desktop\avnotify.exe
> Set the security level to Disallowed > OK
Also block these two files from accessing the internet, using Comodo Firewall or similar software:
C:\Program Files\Avira\AntiVir Desktop\apnstub.exe
C:\Program Files\Avira\AntiVir Desktop\ipmgui.exe
For Windows XP Home you would need to boot into safe mode and log in as Administrator, then
go to
and right click on it >
Properties > Security > Advanced > Edit > Select options not to let it execute for all users.
To submit a suspected virus, go to
[url]http://analysis.avira.com/samples/[/url]
to upload it.
You can scan multiple drives inside program options: Local Protection > Scanner > CHECK drives you wish to scan. The premium version also offers the option to scan multiple folders here. The free version does not.
In case of error message:
The procedure entry point ?_Xbad@tr1@std@@YAX4error_type@regex_constants@12@@Z could not be located in the dynamic link library MSVCP90.dll
download and install Microsoft Visual C++ 2008 SP1 Redistributable Package
[url]http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=a5c84275-3b97-4ab7-a40d-3802b2af5fc2[/url]
Manual updates can be downloaded from:
[url]http://dl.antivir.de/down/vdf/ivdf_fusebundle_nt_en.zip[/url]
Unzip the downloaded file and copy all the contents to
Using two Antivirus programs at the same time:
If there are two Antivirus programs installed, you should not have two Antivirus *Guard* programs active at the same time because this would slow the system down, Windows may even have problems booting with two Antivirus guard components being active. So if installing AntiVir on a system where there already is an Antivirus program installed, do not install AntiVir guard.
Also disable the guard component of one program if using another program to scan an entire disk drive.
Default log file location is
C:\ProgramData\Avira\AntiVir Desktop\LOGFILES
or
C:\Documents and Settings\All Users\Application Data\Avira\AntiVir Desktop\LOGFILES
For older versions:
C:\Documents and Settings\All Users\Application Data\Avira\AntiVir PersonalEdition Classic\LOGFILES
C:\Program Files\Avira\AntiVir PersonalEdition Classic
or
C:\Program Files\Avira AntiVir Personal\
C:\WINDOWS\Application Data\Avira AntiVir Personal\LOGFILES
Comodo Firewall 2012 product version 5, 12, 256249, 2599
Version 5.12 is compatible with Windows 8. That is the only difference between v5.10 and v5.12. There are no other different features. On Windows 7/XP machines, installing v5.12 is identical to installing v5.10.
Double click on Setup.exe to install the program > OK > UNCHECK everything.
Do not change DNS servers. Do not enable Cloud Based Behavior Analysis.
BEFORE CLICKING ON Agree and install ** CLICK ON CUSTOMIZE INSTALLATION here. **
UNCHECK: Install COMODO GeekBUddy and COMODO Dragon > Back > Agree and Install
First import any saved configurations if you have them:
Right click on the Comodo icon in the task bar > Configuration > Manage My Configurations > Import...
Wait for it to be imported, then click on the imported configuration > Activate
Otherwise, set your custom configuration:
Start the program > More... TAB > Preferences > General TAB > UNCHECK Everything > OK
Firewall TAB > Firewall Behavior Settings [last on right] > General Settings TAB > Custom Policy
then
Alert Settings TAB > Alert Settings > Very Low (Shows only one alert per application) > OK
Defense+ TAB > Defense+ Settings > [last on right] > Disabled > OK
Firewall > Common Tasks > Define any New Trusted/Blocked Applications
To view a list of blocked/trusted applications: Firewall > Network Security Policy
Note that even if you exit this program, it will still block access to other computers on the network if the following are blocked under Firewall > Network Security Policy:
System
Allow And Log IP In/Out From IP Any Where Protocol Is Any
C:\Windows\explorer.exe
Another vote for MSE. I use this on every Win 7 PC I work on or build...It just works, I can set it to update itself, and its green when its working.I'm not sure how sensitive your data is or what OS you're running, but Microsoft Security Essentials and the built in firewall in Win7 is surprisingly good these days for an average desktop user. Free and very unobtrusive.
In the past seven years since first tests were done here, I only know of one alternative with worse virus definitions than Avast and it is AVG.
